Posted July 12, 2017 Hi! I have a spare gtx 750 ti that is just lying around and would like to use it for bitcoin mining. The only problem is that my desktop only has enough room for my current gtx 1060. Is there a way that I could have an external adapter to run my 750 ti to mine using nicehash? And if I could, would there be any major performance loss because of the adapter? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 12, 2017 8 minutes ago, 223342_1454181628 said: Hi! I have a spare gtx 750 ti that is just lying around and would like to use it for bitcoin mining. The only problem is that my desktop only has enough room for my current gtx 1060. Is there a way that I could have an external adapter to run my 750 ti to mine using nicehash? And if I could, would there be any major performance loss because of the adapter? What PCIE slots do you have left on your motherboard? You could just get a riser and plug it in that way. Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/ Stille (Desktop) Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T Evoo Gaming 15" i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD VM + NAS Server (ProxMox 6.3) 1x Xeon E5-2690 v2 - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 12, 2017 its not worth it at all right now but the performance should be fine if you use a USB adapter. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 12, 2017 La Copy Pasta: https://www.newegg.com/Product/ProductList.aspx?Description=Pci-e riser cable&Submit=ENE Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/ Stille (Desktop) Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T Evoo Gaming 15" i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD VM + NAS Server (ProxMox 6.3) 1x Xeon E5-2690 v2 - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 12, 2017 Bitcoint mining is by far not worth it anymore and Ethereum has benn dropping more and more and is probably not worth it either depending on your electricity prices. It is always mined cash - electricity bill - devalutaion of GPU/ other product used) = gains. http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:1. FOLLOW your own topics 2.Try to QUOTE people so we can read through things easier 3.Use PCPARTPICKER.COM - easy and most importantly approved here 4.Mark your topics SOLVED if they are Don't change a running system Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 12, 2017 Author 1 hour ago, GER_T4IGA said: Bitcoint mining is by far not worth it anymore and Ethereum has benn dropping more and more and is probably not worth it either depending on your electricity prices. It is always mined cash - electricity bill - devalutaion of GPU/ other product used) = gains. The problem is that I don't have any more pcie slots because I have a smaller motherboard. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
