Recently I just upgraded my PC to an i3 7100 ddr4 ram and a B250M Motherboard.  When booted up I downloaded the OS windows 7 ultimate 64bit. I tried to download the Motherboard drivers via the disk it came with but nothing showed. I went to another pc and copied everything I needed onto a USB drive. When I came to my pc I plugged the USB drive and nothing popped up. I don't have internet on my computer so I can't download the drivers for the internet and other hints online. My cousin which is a computer expert will not be able to help me as he is on vacation.
https://linustechtips.com/topic/803740-need-help-with-b250m/
5 minutes ago, kehvin said:
I don't have internet though
How are you accessing this forum?
You can't install windows without internet
EDIT: you can but not activate
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/803740-need-help-with-b250m/#findComment-10103176
1 hour ago, kehvin said:
Any way to get windows 10 on my pc online without having to order it or somewhat
You can upgrade fast
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/803740-need-help-with-b250m/#findComment-10103394
3 hours ago, Electronics Wizardy said:
buy a dvd?
You really have no access to the internet? Thats gonna make it so you can't do many things like activate the os or update it.
I have a USB drive that has windows 10 and, what if I already have an OS on my computer? When I try to install windows 10 it saids that I already have an operating system etc etc
https://linustechtips.com/topic/803740-need-help-with-b250m/#findComment-10103972
the os isn't on the computer, its on the hdd or ssd
What drives and os's do you have? You can delete the exisitng partitions if you want.
https://linustechtips.com/topic/803740-need-help-with-b250m/#findComment-10104126
