Do i need an optical drive?
Go to solution Solved by Jdel999,
Creating a bootable usb stick is easy and simple, if you are using windows then the windows media creation tool has the option to create a bootable usb stick, and if you are using anything else just use the rufus tool to put the .iso file onto a usb stick and make it bootable
USB drive.
Presuming you are buying a copy of windows 10, make sure you order the usb version.
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
You can get portable usb dvd drives for 10-20 bucks at many places.  At that price, I would say get one, make sure it works and you know how to use it, and then put it back in the box and in your drawer.  It'll be one of those cases where you may not need it often, but when you do need, it'll be there.  Cause if you do need one, but you don't have it, you're going to hate yourself for not spending $20.
