Sup folks,
I'm still planning out my build and was wondering something that some of you might know. I want to make a junction from the power-LED cable to an LED Ford emblem that I've got (simple, split the wire from the front panel LED, add wire junction, add the rest of the power-LED wire + the LED emblem and voila) Now my emblem (pics below)  is rated for +/- 12V, so I was wondering, how much voltage comes from the power-LED pins? Would it be enough to power it?
TL;DR:
How much voltage comes from the front panel power-LED pins?
Thanks in advance,
Cheers,
TJ
https://linustechtips.com/topic/802758-voltage-output-power-led/
Why not just check with a multimeter?
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
7 minutes ago, ThomJV said:
Sup folks,
TL;DR:
Thanks in advance,
Cheers,
TJ
Your going to need to wire it directly to 12V from the PSU the front panel LED headers are only around 3.0V and are current regulated.
-Moved to Modding Section-
Edited by W-L
Thanks, also for moving the post, I'll be more cautious as to where to put it in the future.
In regards to the LED emblem, I guess I'll wire it straight from a molex-connector, as I believe those are 12volt, I'll do some more research.
Thanks again!
Thanks again!
Yeah that will work.
