hi guys, i need help building an ATM system for my class, i need it to be able to change my security pin for a new one but i have no idea how to write the code for that, I have everything else finished and i just need that part but i've tried alot of stuff and no clue ... please help :(
https://linustechtips.com/topic/802313-c-help/
You need to give us some more information about what it is exactly that you want to do, I can't understand what you mean by
What's the security pin, what are you trying to change it to/from? Are you trying to encrypt/decrypt it or are you just assigning the variable a new value based on the security pin? Have you googled around for a solution? What is it exactly you don't know what do?
https://linustechtips.com/topic/802313-c-help/#findComment-10087969
1 hour ago, Nuluvius said:
Oh look it's another one of those 'do my homework for me while I contribute absolutely 0 effort' threads.
How about no.
its not like that here have a look at my code if you want, the text is in spanish because im from Honduras
CAJERO COMPLETO.txt
https://linustechtips.com/topic/802313-c-help/#findComment-10090010
Sorry for not being specific!
first of all, i have to write an "ATM" system and i have already defined a value for the security pin, but one of the options that my ATM has to have is to change the security pin if you decide to, but i dont know how to, because i have already assign an specific security pin for different users and if they decide to change it by running the program they must be able too.
here is the code i have so far and the "cout" text is in spanish because im from honduras
i just need help with the security pin and yes i've googled the solution but found nothing.
I'm using Dev C++ btw!
CAJERO COMPLETO.txt
https://linustechtips.com/topic/802313-c-help/#findComment-10090017
CAJERO COMPLETO.txt
Again, why should I go to the effort of downloading your text file and trying to decipher your work? You haven't even been bothered to follow the guidelines by presenting your code properly i.e. putting it into code tags.
The single biggest problem in communication is the illusion that it has taken place.
https://linustechtips.com/topic/802313-c-help/#findComment-10090119
ok first of all im new at this and im beginning to learn programming so from what i understand this is a forum for and helping others learning, i would appreciate some helpfull advice from people that know and not this stupid comment criticizing the work of a learning student.
https://linustechtips.com/topic/802313-c-help/#findComment-10091361
You've completely missed the point. It's got absolutely nothing to do with the quality of your work. It has to do with your lack of effort and observational skills, for example:
https://linustechtips.com/topic/802313-c-help/#findComment-10092108
instead of argue with me you could have just helped me and told me what to do next time i need help and be done with this, so what i didnt use the tags ? nobody will be harmed if i use them or not, i just need help right away and again if you're not going to help becuase you don't care then get lost, simple as that and maybe someone else my want to help me.
https://linustechtips.com/topic/802313-c-help/#findComment-10092321
58 minutes ago, AndyLSB said:
instead of argue with me...
No one is arguing with you.
59 minutes ago, AndyLSB said:
...you could have just helped me and told me what to do next time i need help and be done with this...
That is exactly what I did.
...so what i didnt use the tags ?
Unfortunately it serves to highlight/compound your lack of effort.
...nobody will be harmed if i use them or not...
You seem to be missing the point yet again:
...i just need help right away...
Your desire for expedient help is 'harmed'; first by your lack of effort and now by your obnoxious attitude since being called out on it:
if you're not going to help becuase you don't care then get lost, simple as that...
You made another mistake in statement: You made the assumption that 'I don't care'. Perhaps you should ask yourself why I'd still be replying to you if that were true. I'm trying to get you to pay attention to detail.
...maybe someone else my want to help me
It's unlikely. We see a few of these crop up from time to time. Many of us have jobs and a few of us have families. Quintessentially you're asking us to donate some of our time to help you with your problems... The least that you could do is to show some effort and meet us half way don't you think. Of course you're always welcome to wait.
https://linustechtips.com/topic/802313-c-help/#findComment-10092611
The problem is that you have this over-arching problem, that you need to split into smaller problems.
I'm not going to give you the code to do it, but here is a general overview of what you probably need to do:
When you ask the user if they want to change their security pin (I'm not sure exactly how you do it, I'm sorry I don't speak Spanish), you just need to prompt the user to input a number for example "1234", then convert that number to an integer and store it in the variable you're using for the security pin.
If you wanted to go a step further you could probably have a collection of names and their associated pins, credit card numbers, etc. in a JSON file (or a text file, but that would mean you would have to have an arbitrary formatting for the text file, which wouldn't be very expandable, so they don't have to enter their details every time they run the program, you could just prompt them with a "Are you new [Y/N] > ", or something similar.
I hope this broke the problem down a little bit so you could understand it better, good luck with your project! :D
https://linustechtips.com/topic/802313-c-help/#findComment-10092709
you're right, i'll do that next time, thanks.
https://linustechtips.com/topic/802313-c-help/#findComment-10093538
thanks for the help man but i'm still blocked in the change security pin menu i wrote
#undef "variable" but for it to save the new value is what i cant do. if i want to go and change user i must be able to use the new password. i've tried alot of stuff
https://linustechtips.com/topic/802313-c-help/#findComment-10093548
Well you could just edit your post/s.
i'm still blocked
That way you may get more help.
https://linustechtips.com/topic/802313-c-help/#findComment-10094315
14 hours ago, AndyLSB said:
iso what i didnt use the tags ? nobody will be harmed if i use them or not, i just need help right away...
You do realize some of us will actually try your code and possible modified solution code as to make sure the given answer actually compiles and works. Code that's been posted properly, with the code tags, can be copy pasted, a picture cannot. If you expect ppl to manually re-type your code in order to test it you'll be waiting for a long time.
https://linustechtips.com/topic/802313-c-help/#findComment-10094953
In addition nobody wants to download a random file that the forums will not automagically format and put up in the post. You can convince us all you want you sent a .txt file, but I'm not going to download it.
At the very least, use something like Pastebin.
https://linustechtips.com/topic/802313-c-help/#findComment-10096055
show me how to post it properly i dont understand and if no one else is whilling to help me then fine i going to look for help some place else, its fine.
I don't really enjoy repeating myself:
Did you follow the link provided?
https://linustechtips.com/topic/802313-c-help/#findComment-10099666
