So the issue I am having is I wanna watch a live stream on my smart TV. Currently when I try to watch the live stream ( https://creationfest.com/livestream/ ) it says we need adobe flash. I read up on the Samsung website that the firmware on the smart TV prevents flash from being downloaded due to security concerns. I also read that there is an adobe air that came out in a firmware update. I don't know much about smart TVs, so dose anyone know a work around or simple fix for this issue?
https://linustechtips.com/topic/800637-samsung-smart-tv/
Plug it into a computer.
https://linustechtips.com/topic/800637-samsung-smart-tv/#findComment-10069757
yup, i'm afraid this is your only option. or get a compustick and plug a computer into the tv instead :P
smart tv's aren't that smart when it comes to content provided outside the "big known ones" like youtube, netflix etc..
to be able to watch whatever you want, get a compustick or a cheap NUC
Have you tried to perform a sudden temporary interrupt of the electricity flow to your computational device followed by a re-initialization procedure of the central processing unit and associated components?
Personal Rig Specs
CPU: Intel Core i7-7700K @ 4.8GHZ
Motherboard: Asus ROG STRIX Z270H GAMING
Graphics Card: Inno3D ICHILL GEFORCE GTX 1080 TI X3 ULTRA
RAM: Corsair Vengeance LPX Black DDR4 2x8GB @ 3GHZ
Storage: 2 x Samsung NVMe SSD 960 EVO 256GB in Raid | 2 x Seagate 4TB Expansion Desktop
(seagates are originally external drives removed from casing and installed internally)
PSU: Seasonic Prime Titanium 850W
Case: Mission SG GGX 3.5 (same as Rosewill Cullinan or Anidees AI Crystal with other stock fans)
Cooling: Kraken X62 for CPU, Corsair H55 with NZXT Kraken G12 for GPU
https://linustechtips.com/topic/800637-samsung-smart-tv/#findComment-10069796
