I need help about my Montior (PROBLEM)
Solved by peabody505,
Graphical Issue Generic Checklist:
1. Try rebooting.
2. Check the connections between the cable and both your monitor and your PC.
3. Update your graphics drivers.
4. Try a different cable if you can.
5. Try a different monitor if you can.
6. Try a different GPU if you can.
Please let me know if after all this your problem is still present. Also just for the future posting your hardware/driver versions will be helpful for people to diagnose your issue. What kind of monitor/gpu/drivers do you have? Also how long has this issue been going on?
