RYZEN Workstation Build
Go to solution Solved by domandric034,
7 minutes ago, AkiTech said:
Hey LTT, I'm looking to build my first RYZEN workstaion build on a budget.. can someone please assist me in parts picking.. Im on a $900 budget
My current components of choice are:
Ryzen 5 1600
Gigabyte GA A320M - HD2
GTX 1050 Ti / Gigabyte RX 550 OC
Help me out guys :3
1. RX 550 is equliavent GT 1030.
2. Get R5 1600 with RX 580 or GTX 1060
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($195.69 @ SuperBiiz)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($77.98 @ Newegg)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory  ($135.88 @ OutletPC)
Storage: Kingston - SSDNow UV400 120GB 2.5" Solid State Drive  ($55.98 @ Directron)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.44 @ OutletPC)
Video Card: Asus - Radeon RX 580 8GB ROG STRIX Video Card  ($280.98 @ Directron)
Case: Corsair - 200R ATX Mid Tower Case  ($54.99 @ Amazon)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.23 @ NCIX US)
Total: $914.17
Generated by PCPartPicker 2017-06-17 05:47 EDT-0400
Ryzen 5 1600
Help me out guys :3
https://linustechtips.com/topic/794530-ryzen-workstation-build/
get 1050 ti as it is better supported for workstation use
get the cheapest 16GB of ram you can find
any cheap case will do
get a 550w gold psu or something, don't skimp out on your power supply quality
Maybe get a slightly more expensive motherboard? You may get more ports and stuff if you spend like $10-20 extra for a b350 board
hello!
is it me you're looking for?
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
Cooler: Dark Rock Pro 3
RAM: 32GB DDR4
GPU: GTX 1080
Storage: 1TB 850 Evo, 1TB HDD, bunch of external hard drives
PSU: EVGA G2 750w
Peripherals: Logitech G502, Ducky One 711
Audio: Xonar U7, O2 amplifier (RIP), HD6XX
Monitors: 4k 24" Dell monitor, 1080p 24" Asus monitor
Laptop:
-Overkill Dell XPS
Fully maxed out early 2017 Dell XPS 15, GTX 1050 4GB, 7700HQ, 1TB nvme SSD, 32GB RAM, 4k display. 97Whr battery :x
Dell was having a $600 off sale for the fully specced out model, so I decided to get it :P
-Crapbook
Fully specced out early 2013 Macbook "pro" with gt 650m and constant 105c temperature on the CPU (GPU is 80-90C) when doing anything intensive...
A 2013 laptop with a regular sized battery still has better battery life than a 2017 laptop with a massive battery! I think this is a testament to apple's ability at making laptops, or maybe how little CPU technology has improved even 4+ years later (at least, until the recent introduction of 15W 4 core CPUs). Anyway, I'm never going to get a 35W CPU laptop again unless battery technology becomes ~5x better than as it is in 2018.
Apple knows how to make proper consumer-grade laptops (they don't know how to make pro laptops though). I guess this mostly software power efficiency related, but getting a mac makes perfect sense if you want a portable/powerful laptop that can do anything you want it to with great battery life.
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003390
Requests for parts lists are normally posted in 'New Builds and Planning'. I've asked a mod to move it there so you get more views. I'll post a build shortly.
What programs are you going to be using? How much of a focus is on gaming?
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003392
noted.. I'll get the MSi Mortar B350 instead
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003397
Get B350 mobo
Get high speed RAM
Get a decent PSU like Corsair CX-M grey, Seasonic S12II/M12II-EVO or EVGA B3
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003399
this builds sole purpose is for content creation.. :3
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003400
Also, you don't live in the US, so US parts and prices are meaningless unless you have a way to transport them frmo the U.S. to the Philippines.
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003402
Poor explanations.
1. 1050TI is more powerful
2. Cheapest means low speed RAM, Ryzen loves high speed RAM
3. Some cheap cases have bad cable management room
4. Efficiency usually means nothing when choosing a PSU, for instance, EVGA NEX has gold certified efficiency but has poor electrical performance
5. B350 allows overclocking most importantly
Desktop specs:
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003406
Ryzen 5 1600
Help me out guys :3
Total: $914.17
My Rig : https://pcpartpicker.com/list/MTBd2R
My VM Server : https://pcpartpicker.com/list/rPR6gL
My Backup Server : https://pcpartpicker.com/list/cRQYYr
My Storage Server : https://pcpartpicker.com/list/tzzR9W
My Router : https://pcpartpicker.com/list/bMPN4C
My Laptop : Lenovo Z575 with 6 GB RAM (1866 MHz), Crucial MX300 525 GB & Western Digital 2 TB (Removed optical drive)
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003416
20 minutes ago, ZM Fong said:
Poor explanations.
1. This is a workstation build, what matters is support for the graphics card, and cuda generally has better support, power doesn't matter as much in this case. heck even a really cheap RX card may be better for certain cases.
2. good point, I thought high speed ram was too expensive for some reason, turns out it's actually pretty cheap for the 16GB kits
3. I should have said cheap cases from a reputable brand
4. good point, probably should refer to this guide
5. barely anyone overclocks (too risky for someone with no money anyways, of course if you have disposable income you should overclock), and this is a budget build we are talking about, overclocking requires a better cooler (65W cooler on 1600 probably doesn't have enough headroom I think).
edit: for a workstation build, having more usb ports, sata ports is more helpful than just overclocking support.
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003442
Total: $914.17
RX?
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003463
Good choices, but for a content creation build more storage is a must.
Getting an RX 570/470 and using the savings to get 240GB SSD and 2TB HDD would be much better choices IMO. upgrading 120GB>240GB and 1TB>2TB doesn't cost much extra.
EDIT: for content creation, a 1060 3GB may be better with CUDA and NVENC, although I would rather get a 1050 ti 4GB.
I guess it depends on the type of content creation, is it gaming content creation, video editing, etc?
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003471
No. just no. I wouldn't downgrade GPU. 120 GB SSD is enough with 1 TB HDD. He can later save and just slap in HDD. That is a huge mistake.
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003479
120GB SSD isn't enough to store the adobe applications if video editing is what he is doing.
OK I guess he will be fine with 1TB HDD, but 2TB isn't too much more.
I suppose for futureproofing getting an 8GB card may make sense, but 4GB RX470 makes much more sense in the short term (1-2 years) considering his budget.
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003500
Maybe he will use Sony Vegas Pro which uses better AMD GPU's and RX 580 is golden spot.
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003510
This is source
Thread from sony vegas users.
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003520
35 minutes ago, deXxterlab97 said:
RX?
He said he is video editing. If he will use Sony Vegas Pro then RX is way to go. If Adobe Premiere Pro then GTX 1060.
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003582
13 minutes ago, domandric034 said:
This is source
nothing about RX 580 in there, does extra 4GB in the RX 580 really make that much of a difference? The 570 and 580 are very similar otherwise.
GPU support in vegas is rather old and outdated anyways. Performance seems good enough on my gtx 970 :P
hello!
ᴾC SᴾeCS ᴰoWᴺ ᴮEᴸoW
Desktop: X99-PC
CPU: i7 5820k
Mobo: X99 Deluxe
RAM: 32GB DDR4
GPU: GTX 1080
PSU: EVGA G2 750w
Laptop:
-Overkill Dell XPS
-Crapbook
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003584
Still it's AMD so they keep OpenCL and OpenGL. It makes difference. And Vegas Pro 14 is out so boii take a look at that program.
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003590
16 minutes ago, deXxterlab97 said:
Are they avaialble/in stock in Philipnes?
That will OP check
https://linustechtips.com/topic/794530-ryzen-workstation-build/#findComment-10003666
