Air then. Many air coolers are better than 120mm coolers.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/794158-cooler/#findComment-9999519
I'm using a PureRock on my delidded 6700k ATM while things are being RMAd. 4.4GHz at 1.35v is under 75C
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/794158-cooler/#findComment-9999534
Says it can fit 160mm coolers. Whats your budget? For budget coolers 212 Evo, H7 and Pure Rock are main ones. For midrange U12S, Dark Rock 3 and H5. For higher end D14, Dark Rock 3 Pro.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/794158-cooler/#findComment-10005249
