The size, and that's about it... depending on the model the cooling might be a bit worse but nothing to concern yourself too much.
Personal Desktop":
Luna, the temporary Desktop:
The "Mini" are models that are ideal for ITX formfactor builds. The normal model is ideal for mATX/ATX builds. The difference will be more in the temperatures and noise. The "Mini" models tend to be more noisy due the fan speed/power it needs.
1 minute ago, SHan CHamp said:
SO there's not much difference in Gigabyte GTX 1060 mini and the normal one.. I have AC in my room so heating won't be an issue.. Will the Overclocking be the same in both?
1060 itself doesn't give out much heat, so overclocking is not a problem. Also, it is not necessary to turn on AC just for overclocking. Set a more aggressive fan curve will solve heat problems, if it ever comes.
As for noise, it varies from card to card. A 1060 shouldn't be loading the single fan too much, but check for review videos.
Desktop benching:
2 minutes ago, SHan CHamp said:
They will still be somewhat different but it will at max be around the 2~3fps end result difference, gotta think is it worth your money?
Personal Desktop":
Oh okay. Thank you. Also one more question. I'm confused which one to buy.. Zotac, Gigabyte, MSI, EVGA, Inno3D( not even heard the name anytime) , etc
That's where you have to compare them yourself and see if the dfference is worth your Money (and watch some reviews/comparisons) IMO. Good luck :)
Just like what @deXxterlab97 said
Inno3D is quite popular in my area. Their products are just fine: nothing fancy, nothing wrong.
Desktop benching:
