Room Cooling Solution
Go to solution Solved by LyyK,
24 minutes ago, AshleyAshes said:
Congratulations!  You're going to get to learn how to cut plexiglass!  Or learn to deal with heat...
file.php?id=25371
This. You technically don't even have to ask your landlord. When you move out, remove the mount and smash the living F$#& out of the window and say it was an accident. The landlord shall never know huehue and besides, accidents do happen.
EDIT: Or, simply mount a sheet of plexiglass in the window frame as @AshleyAshes suggested. Working with plexiglass is miles easier than with glass.
13 minutes ago, Captinjigglesworth said:
Hello My computer is in a decent sized room but it heats up the room to 100+ degrees fahrenheit and i am sweating and cant handle it anymore i was wondering if you could help me find a solution to cooling my room that isn't over 500 USD (ik i am poor:()
Man if i had 500USD to cool a room idd feel wealthy :D
could you share some info on your specs?
CPU: 6700k 4.6Ghz GPU: MSI GTX 1070 Gaming X MB: MSI Gaming M5 PSU: Evga 750 G2 Case: Phanteks EVOLV
https://linustechtips.com/topic/793138-room-cooling-solution/#findComment-9988658
Are you sure your computer is heating up this room to over 100deg? Like how hot is your computer? If you're sure it's your computer that's heating up the room, maybe you could try making a basement water cooling solution, sorta like what ant venom did-
also in the winter if your computer really gets THAT hot, you can literally use it as a space heater...
linus sex tips
https://linustechtips.com/topic/793138-room-cooling-solution/#findComment-9988662
open the window and put a fan in the room????? and how hot is your pc like water cool yr pc and put the rad out the window :)
international racing driver
My Build
i5-7600k
hyper x fury 16gb (2133)mhz
asus strix 1070
CM 212x
asus z270-p
corsair 550w psu
agon 1440p 144hz tn monitor
corsair strafe mx silent KB
corsair void rbg (wired)
razer mamba te with firefly mouse pat
ps4 controller using ds4 windows
https://linustechtips.com/topic/793138-room-cooling-solution/#findComment-9988680
1 minute ago, Captinjigglesworth said:
I have a gtx 950 zodiac amp an amd fx 8550 and 6 fans
From everything I've heard, the FX is a heat monster. Maybe spend the $500 for a new Ryzen CPU, mobo, RAM, and maybe a newer GPU?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/793138-room-cooling-solution/#findComment-9988685
I wouldnt be able to because i dont have enough money to get a new prossesor or gpu bc that would need a new mobo bc my fx is am3 and the ryzen is am4 and gpu is way over my puget
https://linustechtips.com/topic/793138-room-cooling-solution/#findComment-9988693
You could mount an AC unit in your window.
[ Intel i7-6700K ][ Asus TUF Sabertooth Mk1 Z170 ][ Gigabyte GTX 780ti ][ 32GB (2x16GB) 3200MHz G.Skill Trident Z ][ Corsair Obsidian 900D ]
[ EVGA SuperNOVA 1000 P2 80+ PLATINUM ][ 1x512GB Samsung 960 Pro M.2 (OS) ][ 3x512GB Samsung 850 Pro RAID 0 ][ 1x5TB WD Black ]
https://linustechtips.com/topic/793138-room-cooling-solution/#findComment-9988698
Here, cheaper than spending $500 to cool the room. Just get a cooler PC:
PCPartPicker part list: https://pcpartpicker.com/list/bb9R6X
Price breakdown by merchant: https://pcpartpicker.com/list/bb9R6X/by_merchant/
CPU: AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($87.89 @ OutletPC)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory  ($135.88 @ OutletPC)
Total: $398.76
Generated by PCPartPicker 2017-06-14 10:53 EDT-0400
You could spend a bit more and get a new GPU, or just use your old one.
Mouse: EVGA X17
https://linustechtips.com/topic/793138-room-cooling-solution/#findComment-9988707
5 minutes ago, Captinjigglesworth said:
I would need one under 500 i also live in illinois right out of chicago very hot in the summer and very cold in the winter
For a single room, you can get one that will do the job just fine for a bit over $100. Here's just one example https://www.amazon.com/Frigidaire-FFRA0511R1-Window-Mounted-Mini-Compact-Conditioner/dp/B00W2KG92Y/
EDIT: Removed ref from link.
https://linustechtips.com/topic/793138-room-cooling-solution/#findComment-9988716
6 minutes ago, Captinjigglesworth said:
my windows only open from a left to right and a right to left swing so i couldn't remodel my apartment either my landlord would kill
Tada!
https://linustechtips.com/topic/793138-room-cooling-solution/#findComment-9988741
Yeah like Zando suggested, new system only cost you $400, and you have $500 to cool the room
CPU: Ryzen 2 2700@ 4.0Ghz    Mobo: Gigabyte X470 Gaming 7 Wifi    Cooler: EVGA CLC 240    GPU: GTX1080 FTW DT @ 2113Mhz   PSU: EVGA 750W P2
Case: Fractal Design Meshify C   Displays: 34" LG34UC79G, 24" Dell
https://linustechtips.com/topic/793138-room-cooling-solution/#findComment-9988743
https://www.google.ca/search?q=casement+air+conditioner&rlz=1C1CHBF_enCA742CA742&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjy5aSZzb3UAhUDxGMKHdzfA9cQ_AUICigB&biw=1920&bih=974
These are called 'Casement' air conditioners and they are built to fit in windows like that.
Another option is a portable air conditioner, which uses a hose as a plate to exhaust through the window and those will fit most windows.  You can turn plate for the window to orient any way you want.  You can even cut the plate if it's too big for a small window.
portable-air-conditioners-1012347-630.jp
These are the only TRUELY useful suggestions in this thread. No ammount of PC coolign will make your room cooler.  All that does is push the heat out of the computer more efficiently, it still heats the room just the same.  Unless you build some kind of cooling solution that exhaust the air to somewhere OUTSIDE of the room that is, but it'd be a lot easier and cheaper to buy an air conditioner
https://linustechtips.com/topic/793138-room-cooling-solution/#findComment-9988749
those won't work this is what my window looks like i found a pic on google
https://linustechtips.com/topic/793138-room-cooling-solution/#findComment-9988759
