Why Is Nvida control panel so crappy? 30hz instead of 60
7 minutes ago, App4that said:So it's a 1080p monitor?
They're all the same monitor...
6 minutes ago, PineyCreek said:Did the HDMI cable come with the monitor? While the pinouts are the same, there are high-speed variants for higher res, higher FPS.
The one on HDMI isn't the problem, the one having issues is using DP.
2 minutes ago, Abdullahseba said:I've gone thorough all that before.
And read the bloody post.
Can you swap the DisplayPort cables between the two monitors using DisplayPort and see if the problem stays on the same monitor or follows the cable?
2 minutes ago, RadiatingLight said:Maybe your displayport cable is 1.0/1.1, not 1.2+?
try switching displayport cables between the two monitors that aren't working.
There is no such thing as DisplayPort 1.1 or 1.2 cables (see the link in my sig), however there is such a thing as a faulty cable.
