I just got a new system:
i7-3770
Biostar TH61A
1 x 8GB Crucial DDR3
1 x 2GB Team Elite DDR3
RAM running at 1600mhz
Zotac GTX 970
WD Black Caviar 1TB
LG optical drive
my system booted into windows 10 a couple days ago but now it can't boot into the hard drive. i tried two other samsung hardrives, one didn't boot, one shorted the system. It only boots to my Windows Installation CD in my optical drive. WD and Samsung 1 is not spinning. Samsung 2 was spinning before it suddenly started shorting the system. WD got hot. Maybe I mistreated a drive but surely not 3. Anyone can help?
Thanks.
https://linustechtips.com/topic/791842-hard-drive-problem/
What PSU is this?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/791842-hard-drive-problem/#findComment-9973269
18 minutes ago, Javier Ewe said:
its a pretty garbage acbel ezpower 470 psu. weird thing is that it worked before and under stress tests as well.
PSUs deteriorate overtime. Get a new and reliable one, Tier 3 or higher from here:
These can last you through 1-2 new builds.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/791842-hard-drive-problem/#findComment-9973470
are you fairly certain its due to the power supply? also notably there was a electrical noise when samsung 2 stopped spinning.
https://linustechtips.com/topic/791842-hard-drive-problem/#findComment-9973518
Either that or something shorted somewhere, probably PSU.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/791842-hard-drive-problem/#findComment-9973519
