WHY WHY WHY AND WHY
Go to solution Solved by Ezzy-525,
1 minute ago, SirFido said:
If that is correct then the website i am using is wrong. If what you are saying is true, then it makes a LOT more sense. Thank you (:
Always use the manufacturers website.
IS THIS STUPID
10 members have voted
  1. 1. IS THIS STUPID
    • YES
      6
    • YES
      4
Alright, i am a bit pissed at Phanteks right now. So we all know of the beautiful Phanteks Enthoo Evolv ATX GLASS case, and yes that is a really sexy case. But; The cheaper version of it,  Phanteks Enthoo Evolv mATX GLASS, is just as big and has just as much space inside of it but can only fit a micro-ATX motherboard!? There is just as much space inside of the m-ATX version as in every other ATX case, so why can't they just make it fit with an ATX motherboard!?
https://linustechtips.com/topic/788691-why-why-why-and-why/
But they're not the same size...
DAEDALUS (2018 Refit) - Processor: AMD Ryzen 5 - 1600 @ 3.7Ghz // Cooler: Cooler Master Hyper 212 LED Turbo Black Edition // Motherboard: Asus RoG Strix B350-F Gaming // Graphics Card: Gigabyte GTX 1060 Windforce 6GB GDDR5 // Memory: 2 x 8GB DDR4 Corsair LPX Vengeance 3000Mhz // Storage: WD Green - 250GB M.2 SATA SSD (Boot Drive and Programs), SanDisk Ultra II 120GB (GTA V), WD Elements 1TB External Drive (Steam Library) // Power Supply: Cooler Master Silent Pro 700W // Case: BeQuiet Silentbase 600 with SilentWings Mk.2 Internal Fans // Peripherals: VicTop Mechanical Gaming Keyboard & VicTsing 7200 DPI Wired Gaming Mouse
PROMETHEUS (2018 Refit) - Processor: Intel Core i5-3470 @ 3.2Ghz // Cooler: Cooler Master 212 EVO // Motherboard: Foxconn 2ABF // Graphics Card: ATI Radeon HD 5450 (For Diagnostic Testing Only) // Memory: 2 x 4GB DDR3 Mushkin Memory // Storage: 10TB of Various Storage Drives // Power Supply: Corsair 600W // Case: Bitfenix Nova Midi Tower - Black
SpeedTest Results - Having Trouble Finding a Decent PSU? - Check the PSU Tier List!
https://linustechtips.com/topic/788691-why-why-why-and-why/#findComment-9935985
lul, I love posts like this.
|EVGA 850 P2| |1440p PG279Q| |X570 Aorus Extreme| |Ryzen 9 3950x WC| |FE 2080Ti WC|TridentZ Neo 64GB| |Samsung 970 EVO M.2 1TB x3
 |Logitech G900|K70 Cherry MX Speed|  |Logitech Z906 |  |HD650|  |CaseLabs SMA8 (one of the last ones made)
https://linustechtips.com/topic/788691-why-why-why-and-why/#findComment-9935995
Don't know what you are talking about:
ATX Glass: 235 mm x 495 mm x 510 mm
mATX Glass: 230 mm x 453 mm x 400 mm
mATX is 110mm smaller in height, 42 less length and 5 mm less width
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/788691-why-why-why-and-why/#findComment-9935997
Yes, the ATX is four centimeters bigger, but that does not change my opinion. A normal ATX case is just as big as the m-ATX one.
https://linustechtips.com/topic/788691-why-why-why-and-why/#findComment-9936003
Your "opinion" is wrong. The mATX is much, much smaller. It's shorter and shallower, the two main features of an mATX case over an ATX case. The width is negligibly different, sure, but the overall size of the chassis much, much smaller.
https://linustechtips.com/topic/788691-why-why-why-and-why/#findComment-9936023
https://linustechtips.com/topic/788691-why-why-why-and-why/#findComment-9936026
In reality though, its not that big of a difference. They are pretty similar in size. besides mobo cutout.
I can see the argument, but not as much as OP getting this pissed off cause of it :D
https://linustechtips.com/topic/788691-why-why-why-and-why/#findComment-9936053
