Help on building an egpu
Go to solution Solved by Droidbot,
pcie x1 isn't worth it
the issue here is that we don't know how much memory is assigned to the PCIe ports, if there is a whitelist, etc, etc. you circumvent some of these with business laptops that support this, but with your computer it wouldn't likely have these
i guess it will technically work, but it's tons of hassle for little gain.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
https://linustechtips.com/topic/787731-help-on-building-an-egpu/#findComment-9924842
idk
https://linustechtips.com/topic/787731-help-on-building-an-egpu/#findComment-9924881
