Basically any. they're all pretty intuitive.
X299 just came out BTW, so you may want to consider returning your X99 board, and picking up an X299 one.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/786827-cooler-for-x99/#findComment-9914064
I'd wait as @RadiatingLight mentioned.
If you want to proceed, I can recommend some of be quiet!'s offerings like the Pure Rock or Dark Rock.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/786827-cooler-for-x99/#findComment-9914067
I've got a Cryorig R1 Ultimate on my 5820k, and it stays nice and cool at 4.5 ghz 1.31 volts. Under 80 at full load, and mid 30s at idle, while being almost completely inaudible.
Super easy to install as well
Highly recommend
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/786827-cooler-for-x99/#findComment-9914093
Where are you shopping/located? Budget? What else are you looking for in a cooler?
What case are you using?
https://linustechtips.com/topic/786827-cooler-for-x99/#findComment-9915131
9 hours ago, dukenukems said:
I will be using the corsair-c70 case and will be shopping for the cooler online.Either through amazon or newegg.Budget would be $30-80$.
Are you shopping in the US? What are you looking for in a cooler?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/786827-cooler-for-x99/#findComment-9918743
15 hours ago, dukenukems said:
The us,i am gonna give the noctua nh-d15s a try.
The NH-D15S is an excellent cooler but you might want to consider the slimmer NH-U14S which should be a bit easier to install.
https://linustechtips.com/topic/786827-cooler-for-x99/#findComment-9923449
he nh-d15s should be fine since i am not gonna be using tall ram and it will be arriving along with my 5820k tomorrow:).
https://linustechtips.com/topic/786827-cooler-for-x99/#findComment-9923837
