Am I going insane ?
XenosTech
So I'm playing bf1 and this guys hits the chat with "I'm playing bf1 with an i5 and a 1080 and he's getting constant dropped frames. what should he do ?"
So because I told the guy to get upgrade his cpu apparently the chat goes wild and calls me retarded and saying the 1080 is holding back the i5... What ??
CPU: Intel i7 7700K | GPU: ROG Strix GTX 1080Ti | PSU: Seasonic X-1250 (faulty) | Memory: Corsair Vengeance RGB 3200Mhz 16GB | OS Drive: Western Digital Black NVMe 250GB | Game Drive(s): Samsung 970 Evo 500GB, Hitachi 7K3000 3TB 3.5" | Motherboard: Gigabyte Z270x Gaming 7 | Case: Fractal Design Define S (No Window and modded front Panel) | Monitor(s): Dell S2716DG G-Sync 144Hz, Acer R240HY 60Hz (Dead) | Keyboard: G.SKILL RIPJAWS KM780R MX | Mouse: Steelseries Sensei 310 (Striked out parts are sold or dead, awaiting zen2 parts)
Your not he is a less informative person so tell him no matter what get a i7 or better and close all of the background apps and see how much ram he has because BF1 is a ram hog
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
It depends. I've rarely seen my i5 hitting 100% on BF1 without my 1080 being at 100%. I would dig deeper to find what the rest of his hardware is. Taking the bottleneck route is far too easy and unhelpful in my opinion.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Yeah. Giving tech advice in game with 63 other people that like to often visit your mum is the first sign of tech addiction.
You should definitely discuss this with your operator.
1.) depends what the i5 is
2.) ram matters for BF1
3.) SSD or nah?
AsRock X99 Taichi MB // Intel Core i7-6800k Overclocked @ 4.0GHZ // Noctua NH-U14S Cooler // Corsair Vengeance LPX 16GB DDR4 // EVGA GeForce 980Ti SC+ // Samsung 850 EVO 500GB SSD // 2TB WD Gold HDD // Corsair RM850 PSU // Corsair Obsidian Series 750D // Asus VG248QE 144Hz
GIGABYTE GA-Z77X-UD5H LGA 1155 Intel Z77 // Intel Core i5-3570k Overclocked @ 4.2GHZ // Noctua NH-L9x65 Cooler // Corsair Vengeance 16GB DDR3 // EVGA GeForce 960 // 250 GB WD Blue HDD // EVGA SuperNOVA 650 G3, 80+ GOLD // Corsair Carbide Series 100R
if you can splash out for a 1080 you shouldn't be buying an i5 to play bf1... It has been noted that i5's have bad frame times in bf1... Even now with my 1070 is get frame dips while playing that online
He asked a question and got a sensible answer. My answer made more sense than people telling him that he should spend more money buying a 1080 TI
I don't suffer any frame-time issues. Texture pop-in, RAM bandwidth, and background programs can all cause a similar effect.
Damn it!
Looks like you're already in the 2nd stage! You should rush to the Amazon immediately!
You gave him good advice, you're not insane but you are taking it way too personally.
I noticed it when I went from a rx 470 to this 1070... I don't get nearly as high frames with the 1070 and my frame drops pretty hard when I wander into a ton of explosions and fire
3.) SSD or nah?
6600k and more threads matter to bf1 also, ssd won't make much of a difference to the fps (I've played bf1 from my ssd and my 3 TB HDD) I got faster load times but no boost to the fps
DX12 or DX11. I'm using DX11 since it's the more stable for my 4690K.
Look, there may be different causes to his issue.
I also had terrible stutter in BF1 which I resolved by disabling GameDVR and GameBar in Windows 10
I agree that it's most likely a CPU-related bottleneck. Overclocking RAM would help in that scenario, if a CPU upgrade is out of the question of course.
Though what's more important, have you asked about his resolution? If he's playing at 4K for instance, I doubt that there is any chance of a CPU bottleneck with a GTX 1080 so the issue lies somewhere else.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
DX 12 for the 470 and DX11 now that is have the 1070.
well iirc he said his cpu is at 100% and gpu is at 100% but he gets a lot of stuttering. I really didn't dive too much into his entire system specs since I wasn't trying not to die.
2 minutes ago, Morgan MLGman said:
I agree that it's most likely a CPU-related bottleneck. Overclocking RAM would help in that scenario, if a CPU upgrade is out of the question.
I should have asked that or he probably said it but I stopped paying attention to the chat when people started saying the 1080 was holding back  the i5.
6 minutes ago, kb5zue said:
Tell him to join Linus Tech Tips forums, he just might learn something.
I should have told the other players there to join LTT... He somewhat understood what I was telling him.
What resolution do you play at? With my former 2500K @ 4.6 Ghz, I think I was hitting max CPU usage in some places in Bf1 while playing at 1920x1200, probably all settings maxed. With my 2600K @ 4.6 Ghz, playing at 1440p, I think the CPU load has been reduced quite a bit. But I haven't loaded the game up in a long time, and I don't know what % of utilization it actually has, now.
You own the software that you purchase - Understanding software licenses and EULAs
"We’ll know our disinformation program is complete when everything the american public believes is false" - William Casey, CIA Director 1981-1987
I had a i5 4690k which was bottlenecking my 1080 at 1440p. The guy is in denial.
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
If he's at 1080p then he's likely hitting a CPU bottleneck. With that said: the misinformation on here is astounding. You'd think by now people would understand. The word "bottleneck" gets tossed around too loosely nowadays. It doesn't matter if it's on here, reddit or other forums. Honestly, how can anyone possibly think that any relevant i5 (K) processor would bottleneck a 1080/1080ti? Cpu architecture hasn't changed much over the last 5 years. The main advancements have been in integrated graphics which literally means nothing if you're a gamer.
  • General rule of thumb for certain games that are poorly optimized, the higher your resolution - the less likely your cpu will be your "bottleneck".
And before you ask: lower resolutions are easy for graphics cards, so the limiting factor is how fast your CPU can calculate data. Higher resolutions stress the graphics card so the CPU isn't the limiting factor..
i5-4690K @ 4.5GHz |:| Gigabyte Z97X-UD5H |:| Noctua NH-D14 |:| Gigabyte Aorus GTX 1080 Ti XE |:| G.Skill 8GB 1600 |:| Samsung EVO 250GB |:| WD Caviar Blue 1TB |:| XFX 750W BE |:| Corsair 450D |:|
ASUS PG348Q |:| Moon Neo 230HAD Dac/Amp |:| Sennheiser HD 800 |:| Logitech G900 |:| Ducky Premier (MX-Reds)
It's funny how I could run BF1 on Ultra with 64 players on the server. But now that I went to play operations, I got HORRIBLE FPS DROPS. I was like holy shit is my PC exploding. I even lowered render scale to 75% and it helped only a little. Weird game, that one.
My stuff:
CPU :  Intel i5 8400 | GPU : MSI GTX 970 Gaming 4GB
RAM : 32GB Corsair Vengeance DDR4 @ 3600MHz
Mouse : Logitech G502 HERO SE | Keyboard : Mountain Everest Max w/ Cherry MX Brown
Headset : Beyerdynamics DT990 Pro 250Ω w/ AT2020USB+
Monitor : Acer XF240H @  144Hz
It's one of the few dx 12 games that actually uses both the gpu and cpu
EA is known to destroy then fix games with patches.
