What should I Upgrade first
Solved by Technomancer__,
2 minutes ago, Mr.MEESEEKS said:Well i got a 75hz monitor 1440p that is why i want the upgrade but i cant use it so i am using other one at the moment.The reason i have it is friend was moving and he needed to get rid of it and i got it for free.
And its only a 3 months used monitor.
Lucky. Get the zotac gtx 1080. You wont need to upgrade for a while https://www.techpowerup.com/reviews/Zotac/GeForce_GTX_1080_Amp_Extreme/13.html
