I just wanted some insight on this list I put together as a "budget" build, (Parents will be getting the peripherals) anyway, I just want to know if this is a good list and I also wanted advice. Also I'm a sucker for LEDs and RGB. (I reposted this because I wanted to change something).
List: https://pcpartpicker.com/list/xwtczM
https://linustechtips.com/topic/785692-first-pc-build/
PCPartPicker part list: https://pcpartpicker.com/list/CZzmpb
Price breakdown by merchant: https://pcpartpicker.com/list/CZzmpb/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($218.58 @ OutletPC)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($77.98 @ Newegg)
Memory: Crucial - 8GB (1 x 8GB) DDR4-2133 Memory  ($54.77 @ OutletPC)
Storage: Samsung - 960 EVO 250GB M.2-2280 Solid State Drive  ($127.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.33 @ OutletPC)
Video Card: Gigabyte - Radeon RX 580 8GB Gaming 8G Video Card  ($242.99 @ SuperBiiz)
Case: Thermaltake - Versa C22 RGB ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: SeaSonic - S12II 620W 80+ Bronze Certified ATX Power Supply  ($47.78 @ SuperBiiz)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($89.89 @ OutletPC)
Case Fan: Cooler Master - SickleFlow (Blue) 69.0 CFM  120mm Fan  ($4.99 @ Newegg)
Monitor: Acer - GN246HL 24.0" 1920x1080 144Hz Monitor  ($182.99 @ B&H)
Keyboard: Corsair - STRAFE RGB Wired Gaming Keyboard  ($109.99 @ Amazon)
Mouse: Razer - DeathAdder Chroma Wired Optical Mouse  ($49.96 @ B&H)
Headphones: SteelSeries - Siberia 150  Headset
Total: $1316.21
Generated by PCPartPicker 2017-05-28 14:14 EDT-0400
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/785692-first-pc-build/#findComment-9901167
Here is what you should do:
1. Don't get that kingston memory kit. It's super, super, super overpriced. You can get 3000MHz for cheaper which Ryzen greatly benefits from. I added a 1x8 Corsair Vengeance LPX 3000MHz kit.
2. Get a cheaper SSD. I changed it to an SK Hynix SL308. If you can't get one of those, the Mushkin Reactor, Crucial MX300, PNY CS2211, Samsung 850 EVO, or OCZ Trion 150 are also good choices.
2. Don't get a 3GB 1060. It's a poor value and you'll want the extra VRAM. I bumped it up to an RX580 8GB which is far better. The 1060 6GB is also an option, but the RX580 8GB is still a better value.
4. That PSU is okay, but not that great. I changed it to a Corsair CXM 550 which is only $15 dollars more, is far better quality, semi-modular and is 100 watts higher for future upgrade potential.
These changes brought the price up literally 3 dollars and 74 cents. It's a really good tradeoff.
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory  ($73.99 @ Amazon)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($87.88 @ OutletPC)
Video Card: MSI - Radeon RX 580 8GB GAMING X Video Card  ($254.99 @ SuperBiiz)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $1319.53
Generated by PCPartPicker 2017-05-28 14:15 EDT-0400
Desktop - CPU: Ryzen 7 3700x | COOLER: be quiet! Dark Rock 3 | MOBO: ASRock X370 Killer SLI/ac | RAM: 32GB Corsair Vengeance LPX 3200MHz | GPU: MSI RTX 2070 Super Gaming X Trio | STORAGE: 2x XPG SX8200 Pro 1TB, Crucial MX300 525gb, Seagate Barracuda Pro 4TB | CASE: Phanteks P400s TG White | PSU: Corsair HX750i
Laptop - Dell XPS 13 | Intel i7 7500u | Intel HD 620 Graphics | 8GB RAM | 256GB M.2 SSD
Peripherals - KEYBOARD: KBD67 Lite w/Gateron Milky Yellow Pros | MOUSE: Razer Deathadder V2 | AUDIO: Sennheiser HD 6XX, Truthear Hexa | MONITOR: Dual 1440p 27" MSI Optix MAG274QRF-QD
https://linustechtips.com/topic/785692-first-pc-build/#findComment-9901231
