Ok so I came across a old AMD 5550 from an old PC. Right now my other PC can't play anything well. It has a OEM dell 300 watt PSU. Will it work?
The other specs are
Athlon x4 645
6gb or DDR3 RAM
1 HDD
2 Fans
CPU-- AMD FX-8320 (Stock), Motherboard-- ASUS M5A99FX PRO R 2.0, RAM-- Team 8gb 1600Mhz, GPU-- Sapphire 7870 GHz with OC Edition, Case-- NZXT Tempest 210, PSU-- Corsair CX600m, HDD, 1tb Seagate & 2tb WD External, Monitor-- Dell S2240M IPS Display, Keyboard/Mouse-- Some Logitech keyboard and some Dell mouse, Speakers-- Logitech Z533
https://linustechtips.com/topic/78552-will-it-work-on-300-watts/
The other specs are
Athlon x4 645
6gb or DDR3 RAM
1 HDD
2 Fans
The 5550 is better than what you already had?  I'm assuming what you already had was not the 7870 in your signature?
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
https://linustechtips.com/topic/78552-will-it-work-on-300-watts/#findComment-1078015
Yessir
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/78552-will-it-work-on-300-watts/#findComment-1078017
I have 2 different systems. One gaming for me, and one for my family and my brother. The gpu i have know is an integrated HD 4200. can play tf2 on low
https://linustechtips.com/topic/78552-will-it-work-on-300-watts/#findComment-1078202
Yes as long as that PSU doesn't have a HORRIBLE efficiency (it didn't explode yet so I say yes)
What do you mean by terrible efficiency.
https://linustechtips.com/topic/78552-will-it-work-on-300-watts/#findComment-1078207
In that case, just about any dedicated GPU is better than the onboard.
https://linustechtips.com/topic/78552-will-it-work-on-300-watts/#findComment-1078224
like needs 150w but draws 300w out of the socket
ah
https://linustechtips.com/topic/78552-will-it-work-on-300-watts/#findComment-1078286
Ok well i'm going to try this. what is the worst thing that could happen?
https://linustechtips.com/topic/78552-will-it-work-on-300-watts/#findComment-1078289
Your computer could crash or your power supply would fail and it could possibly bring some of your components with it too.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/78552-will-it-work-on-300-watts/#findComment-1078750
Might catch on fire, explode, melt, warp the space/time field into creating a black hole where the power supply used to be dooming us all because you're a jackass like that. :)
Might just turn off.
https://linustechtips.com/topic/78552-will-it-work-on-300-watts/#findComment-1080060
