Posted May 25, 2017 I can't run like a 40 foot Ethernet cable across my house so it's wifi or powerline, I need a solid connection for gaming Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 25, 2017 Kyle did a good video on this. Rig: Thermaltake Urban S71 | MSI Z77 G45-Gaming | Intel Core i5 3570K (4.4Ghz @ 1.4v) | CM Hyper 212 EVO | Kingston HyperX Fury 8GB | MSI GTX 660 | Kingston 120GB SSD | Seagate 3TB HDD | EVGA 850W B2 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 25, 2017 5 minutes ago, barisaxyman said: I can't run like a 40 foot Ethernet cable across my house so it's wifi or powerline, I need a solid connection for gaming it can bebut its completely dependent on the quality wiring in your house and the location of the 2 plugs used. No way to really say for sure you'd just have to test. edit: @aneil1998 the video he used is best case scenario and shows how the difference in plugs chosen can make a difference. Case - Fractal Design Arc Mini R2 : Mobo - Asus Maximus VI Gene : PSU - Corsair AX760 : CPU - Intel i7 4790k w/ EK-Supremacy EVO Copper/Acetal Water Block : Memory - Corsair Vengence Pro 24gb 1600mhz : GPU - Evga GTX 780 Ti Classified w/ EK-FC780 GTX Classy - Acetal+Nickel Water Block : Storage - Samsung 840 Evo 250gb & 850 Evo 1tb SSDs, 2x 6TB External HDDs : Fans - 5x Noctua NF-F12 & 1x NF-S12A : Display - 24in Benq XL2420TE : Rads - Darkside LPX360 & LP240 : Pump/Res - EK-XRES 140 D5 Vario Pump Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 25, 2017 I have had a great gaming experience with Wireless AC. A good wireless adapter and a decent AC router will be reliable and fast, but is more expensive than a powerline kit. But if your house is older, or you need to run powerline across a lot of the house, I think a robust AC setup will be ideal. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 25, 2017 Depend how old is your house, I still get decent ping on my wifi but i use ubiquiti AP lite it may cost a bit more but if you decent size house this would do the trick but if you bigger ones i might consider getting multiple but that will require ruining cat 6 . As i have old house, i didnt want to risk running powerline and in end i happy with my purchase. Magical Pineapples
