No case fans, should I worry about VRM/Chipset temps?
Solved by Vandorlot,
If its an open case, then you dont need any fans, but for optimal cooling you should probably get one 120 mm or 140mm targeted at the cpu fan. On linus' test bench he has a universal fan mount that holds the fan mid air.
Heres a link to it.
http://www.dimastechusa.com/dimastech-flexfan120-black-v20
Featured Topics
cringowy ·
Posted in New Builds and Planning2 -
Pekokopiko ·
Posted in Graphics Cards0 -
1
deanx ·
Posted in Troubleshooting2 -
Bkstrat ·
Posted in Troubleshooting0 -
3
remo233 ·
Posted in Power Supplies6 -
2
3
VioletGiraffe ·
Posted in CPUs, Motherboards, and Memory3
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
