GPU Suggestion! Failing R9 290X Lightning Fan.
Go to solution Solved by Clyne,
Might not have any months left on warranty, but could RMA it. Otherwise just do the fan replacement, check any loose connections or so.
Keeping this simple.
The 3rd fan on the 290X lightning is failing, it wont start when the PC is turned on and the only way to get it to start is to put the fan speed at 80%.
Option 1: Keep 290X, buy new replacement fans. Cheapest option.
Option 2: Buy a new gpu, RX 580/480, Maybe a Fury? Expensive option.
What are your thoughts and opinions.
Let me know!
As always, Thanks for the help!
Intel Core I7 7820X | Asus Rampage VI | Gigabyte RX 580 XTR | 32GB Crucial Ballistix | NZXT Kraken X62
ADATA XPG 256GB PCIe| Cosmos C700P CM | Lepa MaxPlatinum 1050W
https://linustechtips.com/topic/782559-gpu-suggestion-failing-r9-290x-lightning-fan/
rx 580 is almost the same as 290x in performance.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
I don't think it has any warranty left, and I checked all connections and nothing fixes the issue besides running the fans at 80% and then the 3rd fan runs fine.
47 minutes ago, themctipers said:
1.
Interesting, the only reason why I was thinking of the 580/480 was the 8GB of ram.
The 8GB barely makes a difference. Tt'd probs be better to just contact MSI and see what they say even if it's out of warranty, they may be able to rma it or send replacement fans for cheap
Murphy's Law: "Anything that can go wrong, will go wrong"
I'm wondering, does 'kick starting' it work? When the computer boots, try spinning the fan with your fingers and see if it starts up.
Either way, my two cents is to just get a replacement fan/cooler.
Custom pinewood case, Corsair CX 600WRampage 3 Extreme, i7 980x (@4.2ghz) with ML240 Cooler MSI GTX 970, 24gb DDR3, 240gb OCZ Tr150 SSD + 2Tb Seagate Baracuda.
Advocate for used/older hardware. Also one of the resident petrol heads.
I'm not talking from a performance perspective but in the case that a game uses over 4GB of ram.
It has happened a few times and I only game at 1080p.
I tried spinning it with my finger and it doesn't start.
When you turn on the PC I see the fan attempt to start but fails and like I mentioned earlier, the only way is to set the fan speed at a high percentage which in my case I set it at 80%
jebiga kolega, my level of help ends about there.
I appreciate the help either way!
Nema na cemo.
10 minutes ago, ImadKnight said:
Nema na cemo.
Pretpostavljam da govore bosanski?
naravno:P. rodjen sam u Bosni ali sad zivim u svedskoj.
oh wow stvarno? To je cool!
To je bolje nego zivi u Americi hahaha
neznam jeli bolje ali nije lose.
watercool it, keeping that 290x lighting on air is a crime.
CPU: i7 5820k @4.4GHz | MoboMSI MPower X99A | RAM: 16GB DDR4 Quad Channel Corsair LP | GPU: EVGA 1080 FTW Case: Define R5 Black Window | OS: Win 10 Pro
Storage: SanDisk Ultra II 960GB 2x WD Red 4TB | PSU: EVGA 750W G2 | Display:Acer XF270HU + Dell U2515H | Cooling: Phanteks PH-TC14PE
Keyboard: Ducky One  TKL Browns | Mouse: Steel Series Rival 300 | Sound: DT990s
Not worth the money in my opinion.
Amerika nije lose, ali ja radije da se vratim kuci
UPDATE:
For those who might be interested in what the outcome is, I ordered new replacement fans. The fans came yesterday and I installed them and... Works like new!
So the 3rd fan was going/was bad.
Thanks for all the advice/help everyone!
