I'm living in a small upper ground house with my mom and brother. Both of us play games while my mom watch a lot of streaming TV Series and Movies sometimes.
I'm Using a modem and a router for my connection. Router model is Asus RT-N56U. I play a lot of DotA games. If I'm the only one using the internet I get 19-25 ping, If I'm with my brother playing it goes 20-40 ping, sometimes also shoot up to 80. If we are all at the house and mom is watching, ping goes crazy high and unplayable. Our internet connection is 25mbps which should be enough but it isn't. The modem I'm using is from my ISP.
Should I get something like a new all-in-one (Modem + Router) for my connection to fix it or should I just change the modem or router? Not sure how to fix it. Doesn't have any problem with the signal as we all have strong signal through out the house. Never get one signal drop on wifi. No one uses a wired connection btw and we have 2 PC, 1 TV Box, 1 iPad, 3 Phones and 1 Wireless Printer and that's it. Thanks for any help solving it.
CPU: i5-6600k | GPU: MSI Gaming X GeForce GTX 1070 | MB: MSI Z170A Gaming M5 | RAM: 2x8GB Vengeance LPX 2400mhz
CPU Cooler: BeQuiet! Dark Rock Pro 3 | PSU: EVGA Supernova Nex 650 G1 | Case: NZXT H440
https://linustechtips.com/topic/781076-help-on-wifi-gaming/
I play with about 100 or even higher so it's not bad
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/781076-help-on-wifi-gaming/#findComment-9847369
Can you wire the house for Ethernet? It's a bit expensive at about $400 USD, but it's worth every penny.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/781076-help-on-wifi-gaming/#findComment-9847392
5 minutes ago, manikyath said:
how does one even estimate the BOM of wiring a house for ethernet if you dont know said house?
The wire (1000M), tools, plates, jacks for the wall plates, and jacks for the cables themselves. Cost for my house was ~260 USD. About $400 is the average price for the houses that I've done. It should be much lower if he only intends to wire for one room.
8-port switches go for about $50.
https://linustechtips.com/topic/781076-help-on-wifi-gaming/#findComment-9847428
QOS can help when a lot of people are using the internet. Microwaves can interfere with WIFI a lot so keep the hot pockets to minimum.
If your house has good wiring a power line adapter can get around the WIFI interference issues.
if you want to annoy me, then join my teamspeak server ts.benja.cc
https://linustechtips.com/topic/781076-help-on-wifi-gaming/#findComment-9847450
I'll probably do that if I own the house. I would prefer also a wired connection. I notice each room has a ethernet jack. Not sure if I can use it or do something about its wiring. I talked to my ISP before about it and told me that I can only use one ethernet jack and they need to activate it from the outside to be used so I can't just change the location of my Modem and Router.
Not sure what you meant about to keep the hot pockets to minimum and how to avoid microwave from interfering? Does it only interfere when used or not?
4 hours ago, luigi90210 said:
set your QOS settings so your computer has priority over everyone else
Any help about setting that one up? Not sure how I suppose to do that.
4 hours ago, Lethalmonk said:
Might not be your router nor modem. Call your internet provider and tell them to increase your bandwidth
By Bandwidth you mean asking for a higher internet speed right?
https://linustechtips.com/topic/781076-help-on-wifi-gaming/#findComment-9849811
The microwave only causes interference when it is in use.
https://linustechtips.com/topic/781076-help-on-wifi-gaming/#findComment-9850284
well google your router model and see if it supports QOS and if it supports QOS than log into your router and change the setting so that your computer/IP has the highest priority for all internet traffic. You might need to give yourself a static IP address to setup QOS.
only downside to this is you will be slowing down your moms and brothers internet when you're online and it might piss them off.
https://linustechtips.com/topic/781076-help-on-wifi-gaming/#findComment-9855411
