What's the difference between RGB/W and RGB/UV
Solved by Drak3,
RGB/W has a dedicated white LED. If you want white, you actually get white.
RGB/UV has UV LEDs. These give off soft glows with certain things/colors. White objects will have a soft, purplish glow, and if you watercool, you can get UV reactive dyes.
Neither is really better, objectively. They're different, and fill different subroles.
Featured Topics
maka0 ·
Posted in Storage Devices2 -
3
Ivan M. ·
Posted in Storage Devices3 -
AlDowy ·
Posted in New Builds and Planning1 -
Xrniu ·
Posted in New Builds and Planning2 -
8
3
