Help I spilled ramen on my Strafe RGB keyboard.
I need some help here. I spilled ramen on my Strafe RGB keyboard. My computer then started to freak out, my first response was to unplug it and start pulling keycaps. I washed all of the keycaps and dried off the keyboard to the best of my ability. Is there any thing else I can do to improve my chances of it working again?
 put it on a washing line face down
and leave it there for 6-12h
replug it in
I did this when I spilled carbonated water on my Strafe RGB, worked perfect after
idk
Have you sacrificed a virgin meatball up to the great Spaghetti monster ? Remember to dress as a Pirate when you do it or the sacrifice might be rejected.
If that fails can always turn to our God of darkness, Lord Cthulhu but he can he a bit more demanding blood of the unpure and all that, bit of a hassle really.
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
Use some long grain rice or something
then use compressed air
6 minutes ago, AllensCustomComputers said:
...my first response was to unplug it and start pulling keycaps....
That was probably the right move.  The trick will be to wash the keyboard itself somehow or it'll probably be gross, and then let it dry with rice or silica gel packs or something.
you could wash it with isopropyl alcohol if you have enough. displace the ramen with alcohol
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
