Just curious guys I'm just learning how to overclock, started with MSI Command Center moved on to Ryzen Master and now with some confidence I am OC'ing in the BIOS. I have found a sweet spot that was worthy of saving but my question is I don't turn my rig off I put it to sleep so its been on for a week or so I just got on and did a benchmark it was horribly slow did this 3 times so I logged off and restarted and its back to a good OC is this something normal to occur on occasion? Or is it just a glitch and needs a tweek, I've had this OC setup for about a week now and its been rock stable and getting 1726ish on Cinebench R15 the board is an MSI Pro Carbon. Oh and can you guys see my signature with my setup listed I entered it in the profile but I don't see it in my post?
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/778452-odd-overclock-issue/
I've heard many stories of computers doing weird things after being woken up from sleep mode. It seems like an imperfect technology that to me honest seems not all that useful. Computers boot so quickly nowadays that it's useless if you just want to reach the desktop faster and if you're just using it to save state whatever you were working on I wouldn't recommend it anyways because you risk losing the data if something goes wrong while in sleep.
So I never use it but times where I've tested it has yielded strange results. I've seen BIOS updates for some motherboard that are specially for correcting errors when going in or out of sleep state. It's possible since Ryzen is still a baby that future BIOS updates will be released for your board that might correct the issue you're having.
Also no, I don't see any signature/tag at all.
https://linustechtips.com/topic/778452-odd-overclock-issue/#findComment-9817995
Yes, have also seen this bug... even worse is when you put it to sleep in windows, come back to wake the PC and it's completely off, so don't bother sleeping in windows now, it's mostly fine in linux though, have seen a few bugs, but mostly it's fine in linux from what I ahve seen and experienced myself. That's a pretty nice cinebench score BTW, you must have 4Ghz or more for that I'm guessing unless you have pretty fast ram maybe?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/778452-odd-overclock-issue/#findComment-9818034
Thanks I'm a bit shock at it myself as I've seen some overclocks at well over my settings I've stressed it out with aida64 and for shits and giggles I opened about 25 Youtube videos going all at once didn't even blink thing runs at a frosty 27-36C every BIOS update with the exception of the last allowed me to crank up the ram to where it is now still can't get 3200 well I did for a mere 5 seconds before it shit the bed so I rolled it back.
Bench.wmv
https://linustechtips.com/topic/778452-odd-overclock-issue/#findComment-9818089
3 minutes ago, jjohnthedon1 said:
My pc turns full turd if it goes to sleep mode
we had our NUC doing that, turned out to be something with the SSD, it works perfectly but just sleepmode meant never wake up mode to it.
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
https://linustechtips.com/topic/778452-odd-overclock-issue/#findComment-9818362
When mine wakes up the mobo code changes from 24 to 40 and programs just turn to full retard
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/778452-odd-overclock-issue/#findComment-9818367
