Need advice on my choice of PSU!
M_J_S
Hello
This is my first PC build and I am having trouble selecting a power supply unit.
Is 750W overkill? I plan to add more storage,LED lighting and more fans down the road.
Thanks for any advice in advance!590f081d5760c_Screenshot(9).thumb.png.6d80cbff3f2ebc77054790b329b032b9.png590f08a58ae83_Screenshot(10).thumb.png.d4dce7b34ed9c823a04ec247e654a74e.png :)
400 watts would technically be enough. Get something from tier 1-3 from the PSU tier list in my signature that's >= 450 watts.
I would also personally change the 7600k to a 7700k and get a cheap $30~ cooler (like a BeQuiet Pure Rock/Cryorig H7).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
Just now, quan289 said:
Do you planned on sticking a second 1080 in there?
No definitely not
Just now, M_J_S said:
No definitely not
You don't need a 750 in there then.
okay thanks! what are these tiers you are talking about? thanks!
Okay thanks! what would you recommend?
Click on the "PSU Tier list" in my signature and you'll see.
But I'd do something like this (and I'd also get a cheaper case, but I assume you really want a 780T):
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor  ($468.00 @ Centre Com)
CPU Cooler: be quiet! - PURE ROCK 51.7 CFM Sleeve Bearing CPU Cooler  ($45.00 @ PCCaseGear)
Motherboard: MSI - Z270 PC MATE ATX LGA1151 Motherboard  ($184.80 @ Skycomp Technology)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($159.00 @ Umart)
Storage: Sandisk - SSD PLUS 240GB 2.5" Solid State Drive  ($109.00 @ Shopping Express)
Video Card: Gigabyte - GeForce GTX 1080 8GB WINDFORCE OC 8G Video Card  ($699.00 @ PCCaseGear)
Case: Corsair - 780T ATX Full Tower Case  ($249.00 @ Mwave Australia)
Power Supply: XFX - TS 550W 80+ Gold Certified ATX Power Supply  ($119.00 @ PCCaseGear)
Total: $2032.80
Generated by PCPartPicker 2017-05-07 22:02 AEST+1000
PSU Tier List | CoC
No definitely not
Then save some money and get the Corsair RM550x, EVGA 550 G2, Bitfenix Whisper 550M, etc
Total: $2032.80
Solid recommendation, though for about 80 more you can get the 1080Ti (80 USD)
Fractal Design Edison 550 M would be a better deal for the OP if he decides to go with this.
https://au.pcpartpicker.com/product/PHx9TW/fractal-design-power-supply-fdpsued1b550w
Same Seasonic G / S12G platform as that XFX TS Gold, but it's modular and cheaper.
Total: $2032.80
@M_J_SThis looks good but if you're planning on having just one GPU then a case as huge as the 780T is really unnecessary. Get a cheaper case like an NZXT S340 or Fractal Design Define C.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
