AT M50X Comfort Advice
coldice
I just got some AT M50X's and the ear padding is good. My problem is that the headband starts hurting after 10-15 minutes. Do you have any suggestions for how to make the headband more comfortable?
buy new earcups?
idk, bc mine have been super comfy from the day I bought them
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
give Brainwavz earpads a try. Either the hybrid or velour. the difference is huge, although the bass will suffer a little. There's also a stretch mod (or something) over at Head-fi that make it less clamp.
The headband may not fit the shape of your head. So you may want to stretch it one way or another to best suit your head. Or just wear them for a long time to break them in (kinda like new boots).
