Ryzen 1800x Low FPS
Go to solution Solved by suits,
Well the RAM definitely needs a speed bump. Level 1 techs has an excellent video on getting the most out of your ram should you not be able to get it up to 3200MHz. Make sure it's a clean install of windows. And what others stated above.
I am using Ryzen 1800x on Asus Hero vi mobo with Gskill rgb 3200 at 2133 and 1070 amp extreme.
Getting low fps (Fluctuating min 32) in gears of war ultra presets.
Do you guys have any idea why? is there any fix?
Specs:
Laptop (Model):
HP Pavilion 15-p209tx
Motherboard:
Crosshair Hero Vi x370
Processor:
AMD Ryzen 7 1800x
Memory (part number):
F4-3000C14D-16GTZ
Graphics Card #1:
Zotac 1070 Amp Extreme 8GB
Monitor:
LG 27UD68-P - 4K Monitor
Storage #1:
Samsung 850 EVO 250gb x1
Storage #2:
WD Black 1TB x1
CPU Cooler:
Corsair H115i
Case:
Corsair 760T
Power Supply:
Corsair AX 860 i
Keyboard:
Logitech G413 (Black)
Mouse:
Logitech G402 Hyperion Fury
Headset:
Sennheiser pc 8
Mouse Pad:
Razer Goliathus
Headset/Speakers:
Onkyo HT-S3500
OS:
Windows 10 Pro 64 Bit
Network Router:
Netgear AC3200 Nighthawk X6
Accessory #1:
Microsoft Xbox Wireless Controller
Accessory #2:
Raspberry Pi 2 x1
Accessory #3:
Raspberry Pi 3 x1
https://linustechtips.com/topic/775176-ryzen-1800x-low-fps/
are you using high performance mode in the power settings?
what is your full PC build specs?
all drivers updated?
BIOS is a must to update
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/775176-ryzen-1800x-low-fps/#findComment-9778849
Setting your memory to run at the rated speed wouldn't hurt either, Ryzen likes fast RAM
https://linustechtips.com/topic/775176-ryzen-1800x-low-fps/#findComment-9778885
Ryzen 1800x
Hero vi mobo.
Trident RGB Ram 8x2 3200mhz
PSU AX860i
Cabinet 760t
Samsung 850 evo
Wd black 1tb
Seagate 2 tb
Drivers are updated bios as well latest 1107.
I am unable to run rams at 3200. Tried manually with stock timings DOCP standard 1.35 volt, but no go.
Specs:
Laptop (Model):
Motherboard:
Processor:
AMD Ryzen 7 1800x
F4-3000C14D-16GTZ
Graphics Card #1:
Monitor:
Storage #1:
Storage #2:
WD Black 1TB x1
CPU Cooler:
Corsair H115i
Case:
Corsair 760T
Power Supply:
Corsair AX 860 i
Keyboard:
Mouse:
Headset:
Sennheiser pc 8
Mouse Pad:
Razer Goliathus
Headset/Speakers:
Onkyo HT-S3500
OS:
Network Router:
Accessory #1:
Accessory #2:
Raspberry Pi 2 x1
Accessory #3:
Raspberry Pi 3 x1
https://linustechtips.com/topic/775176-ryzen-1800x-low-fps/#findComment-9791529
Ryzen 1800x
Hero vi mobo.
PSU AX860i
Cabinet 760t
Samsung 850 evo
Wd black 1tb
Seagate 2 tb
Specs:
Laptop (Model):
Motherboard:
Processor:
AMD Ryzen 7 1800x
F4-3000C14D-16GTZ
Graphics Card #1:
Monitor:
Storage #1:
Storage #2:
WD Black 1TB x1
CPU Cooler:
Corsair H115i
Case:
Corsair 760T
Power Supply:
Corsair AX 860 i
Keyboard:
Mouse:
Headset:
Sennheiser pc 8
Mouse Pad:
Razer Goliathus
Headset/Speakers:
Onkyo HT-S3500
OS:
Network Router:
Accessory #1:
Accessory #2:
Raspberry Pi 2 x1
Accessory #3:
Raspberry Pi 3 x1
https://linustechtips.com/topic/775176-ryzen-1800x-low-fps/#findComment-9791530
have you upgraded your GPU recently if so i  would recommend wiping every to do with gpu drivers and reinstall them :) best of luck
https://linustechtips.com/topic/775176-ryzen-1800x-low-fps/#findComment-9791548
Already did, no go.
Specs:
Laptop (Model):
Motherboard:
Processor:
AMD Ryzen 7 1800x
F4-3000C14D-16GTZ
Graphics Card #1:
Monitor:
Storage #1:
Storage #2:
WD Black 1TB x1
CPU Cooler:
Corsair H115i
Case:
Corsair 760T
Power Supply:
Corsair AX 860 i
Keyboard:
Mouse:
Headset:
Sennheiser pc 8
Mouse Pad:
Razer Goliathus
Headset/Speakers:
Onkyo HT-S3500
OS:
Network Router:
Accessory #1:
Accessory #2:
Raspberry Pi 2 x1
Accessory #3:
Raspberry Pi 3 x1
https://linustechtips.com/topic/775176-ryzen-1800x-low-fps/#findComment-9791655
