Need help choosing a 1070
Solved by khazad,
18 minutes ago, Brooksie359 said:If you are going for a red and black build idk why you wouldn't just get the gaming x as it is red and black. It's a wonderful card and I don't have a single complaint I can think of other than it doesn't fit all color schemes.
I've been looking for builds with the Gaming 7 motherboard on pcpartpicker, and saw these two, this is with the Gaming X, and this is with a custom backplate.
I thought a white/silver GPU would make a nicier look because of the white parts of the motherboard.
So i think i'll go with the Gaming X instead
