6 minutes ago, KinkoFTW said:
i have formated windows10
What do you mean by this?
https://linustechtips.com/topic/774196-realtek-audio-problems/#findComment-9766893
10 minutes ago, KinkoFTW said:
i formatted after it happened sorry
That doesn't make any sense.
You can't format windows from within windows, that's not possible.
Are you trying to say that you clean installed windows?
Or that you uninstalled the drivers?
Or what?
BTW, use the quote button if you want to reply to someone.
         V
https://linustechtips.com/topic/774196-realtek-audio-problems/#findComment-9766958
HDMI passthrough?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/774196-realtek-audio-problems/#findComment-9766980
Just now, KinkoFTW said:
i dont have a passthrough
Check your monitor for a "Audio Out" headphone jack if you are using HDMI or Displayport to connect to your monitor.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/774196-realtek-audio-problems/#findComment-9766999
1 minute ago, KinkoFTW said:
i have 2 hmdi out to 2 monitors no audio from the monitors either. sorry i was confused
Whats full system specs?
BTW the monitor audio won't show Realtek, it will show "AMD HD" or "NVIDIA"
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/774196-realtek-audio-problems/#findComment-9767013
its amd hd
inteli3
Motherboard and PSU? RAM? Which AMD GPU and which Intel i3? There are so many models.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/774196-realtek-audio-problems/#findComment-9767032
If you enable AMD HD as the Default Audio Playback device(click on it, then SET DEFAULT), and plug your speakers/headphones to the monitor, do you get any audio?
Could you reset your BIOS to factory default settings? There might be a small chance you or someone else disabled the realtek audio in the BIOS, thus why you're not seeing it in Windows anymore.
https://linustechtips.com/topic/774196-realtek-audio-problems/#findComment-9767364
