I just built a new computer with the following parts:
Video card: MSI GAMING Radeon RX 480 GDDR5 4GB CrossFire VR Ready FinFET DirectX 12 Graphics Card (RX 480 GAMING X 4G)
CPU: Ryzen 7 1700
Ram: G.SKILL Ripjaws V Series 8GB (2 x 4GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel Z170 Platform Desktop Memory Model F4-3200C16D-8GVRB
Motherboard: ASUS LGA1151 DDR4 DisplayPort HDMI SATA 6Gb/s USB 3.1 H170 ATX Motherboards H170 PRO GAMING
Power supply: evga 500b
samsung ssd 250 gb
Dell mouse, keyboard, monitor
when I turned it on for the first time, none of the peripherals (mouse, keyboard and monitor) would not turn on. I tried to plug my cell phone charger into the USB ports, and they started charging my phone so there it power going to them. I tried to take out the battery and wait for about 10 minutes and it didn't solve the problem. I've taken out the ram and gpu and turned the computer on with one of each plugged it and that didn't solve it.
What is the problem because I have no idea at this point? Are my parts even compatible?
Front panel USB or on motherboard?
  • Did you turn on the monitor, and plug it in?
  • Is the monitor plugged into the video card?
  • Did you restart after plugging in the peripherals?
  • Have you tried different USB ports?
  • Did you plug in power to your graphics card?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
omg fix formatting for dark theme pls, its actually invisible unless highlighted
highlight all text and click the remove formatting button (Tx all the way to the right next to Size)
send detailed pics of the mobo's connections and all PSU cabling
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
Yes the monitor is both plugged in and turned on, when I turn the computer on, it just stays in power saving mode like it has no signal going to it
The monitor is not HDMI it has the screws on both sides of the plug and plugs into the motherboard
I have restarted many times
Yes I have tried all of them
the power to my graphic card is plugged in as well
you know, there's a dark theme fixer by Mr. Mortis here
M1 MacBook Air 256/8 | iPhone 13 pro
2 minutes ago, SpaceGhostC2C said:
No, your motherboard is not compatible with your CPU. You wouldn't even be able to fit it in.
I thought that the motherboard would be compatible with an AMD CPU, can u suggest another mobo?
send a picture of your mobo... if that CPU fit in it then you have the wrong specs in your post
HOLA NIGHT THEMERS
OTHER TECH I OWN:
1 hour ago, InfamousWolf said:
snip
yeah that is a AM4 mobo but the one in your post was a LGA1151... what model is written between the PCIe slots?
HOLA NIGHT THEMERS
OTHER TECH I OWN:
You should be plugging the monitor into the video card. That should help.
7 hours ago, JJVGaming said:
When I saw z170 and r7 I was thinking u maybe stuffed the CPU in there O_O anyways like the above poster where did you plug the HDMI cable?
Tried both the motherboard and graphics cards, nothing.
I called into the asks tech support, and when going through the steps, I tried one of my rams and I got the following beep code: (1 short, 1 long, 3 long). The guy on the phone told me that the motherboard was bad and to get it replaced for a new one. Could it also be that one of the rams it bad?
