I plan on making YouTube videos in the future and edit videos with pro. Will this CPU do the job
Intel Core i7 6700K 4.00 GHz Unlocked Quad Core Skylake Desktop Processor, Socket LGA 1151 [BX80662I76700K] https://www.amazon.com/dp/B012M8LXQW/ref=cm_sw_r_cp_api_tZ5.ybK6MNQK0
and also will it go together with this motherboard?
ASUS PRIME Z270-A LGA1151 DDR4 DP HDMI DVI M.2 USB 3.1 Z270 ATX Motherboard https://www.amazon.com/dp/B01NGTYV2Q/ref=cm_sw_r_cp_api_L85.yb0SZ31F2
https://linustechtips.com/topic/771519-will-i7-6700k/
You can edit vidoes on almost anything these days, hardware doesn't matter, content does. I have editing vidoes on 10 year old systems just fine.
For the cpu, it works in that board, but id get a 7700k instead, its a bit better in all ways
Id also look at a r7 1700
https://linustechtips.com/topic/771519-will-i7-6700k/#findComment-9736569
If you're getting a z270 motherboard why not just get the 7700k? they cost the same as the 6700k more or less everywhere... and yes it is sufficient for recording, editing, rendering normal youtube videos, but if you plan on live streaming the r7 1700 would be superior.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/771519-will-i7-6700k/#findComment-9736586
while that CPU would work fine for video editing, I would suggest getting either a r7 1700 and an AM4 motherboard or get a i7 7700k
https://linustechtips.com/topic/771519-will-i7-6700k/#findComment-9736588
8 minutes ago, openthatchest said:
hell yes. try to go with a ryzen platform, maybe a 1700x, and make sure you have a good GPU for rendering and stuff
Will this do the job
ASUS GeForce GTX 1070 8GB ROG STRIX OC Edition Graphic Card STRIX-GTX1070-O8G-GAMING https://www.amazon.com/dp/B01HDUVJ1I/ref=cm_sw_r_cp_api_8h6.yb37GDD4K
https://linustechtips.com/topic/771519-will-i7-6700k/#findComment-9736653
Being one of the highest end i7's I'd hope so.
But since the Kaby lake is out, Id suggest getting the new model.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/771519-will-i7-6700k/#findComment-9736654
ryzen paired with gtx1070 should be more than enough.
https://linustechtips.com/topic/771519-will-i7-6700k/#findComment-9736679
OMG yes. try not to get the strix card though. it's more $$$ for RGB. and, all 1070 models are around the same GB and clock speed. just try going with the cheapest 1070 avalible. EVEN A 1050 Ti WOULD WORK GOOD!
https://linustechtips.com/topic/771519-will-i7-6700k/#findComment-9738410
Depending on what type of content you are doing, I'd either go with:
R7 1700 with an X370 motherboard or
R5 1600 with an X370 (or B350 if you don't plan to SLI/crossfire).
No real need to go higher than either of those for price to performance.
if you stick with Intel, I'd do the 7700K with a nice Z270 motherboard.  That's the route I took, and have no regrets, as I also do YouTube.
Midnight Rig - CPU: i7-7700K / Cooler: Corsair h100i V2 / Motherboard: AsRock Z270 Taichi / RAM: G.Skill TridentZ 3200Mhz / GPU: EVGA GTX 1070 FTW2 / SSD: Crucial MX300 525GB / HDD: Seagate Barracuda 2TB 7200rpm / PSU: EVGA Supernova B2 750W
https://linustechtips.com/topic/771519-will-i7-6700k/#findComment-9738546
