What motherboard and where are they?
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/770039-ryzen-5-1600-help/#findComment-9718370
Just now, Banish72 said:
The motherboard is a B350 Gaming Pro
I gtg for now, but I'll try to help you tomorrow :)
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/770039-ryzen-5-1600-help/#findComment-9718383
2 minutes ago, Banish72 said:
I took a picture it's a B350 Gaming Pro
So is the computer working? Because those are debug LEDs that could potentially indicate problems from the looks of it, but if it's up and running fine I wouldn't worry about it.
If it's having some sort of issue, please describe it.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
https://linustechtips.com/topic/770039-ryzen-5-1600-help/#findComment-9718409
I'm being a little blunt, but the information is ALL in the MSI B350M Gaming Pro motherboard manual.
Page 15, Section 'EZ Debug LED: Debug LED indicators'
From your picture, it looks like the "CPU" LED is lit.
  1. Make sure the heatsink fan is properly connected to the CPU_FAN1 header.
  2. Make sure the 8-pin CPU_PWR1 connector is secure, and it ACTUALLY connected.
  3. (Hopefully) the CPU is installed correctly...and not backwards, destroying all the pins...
By the way, is your stick of RAM interfering with the CPU cooler?
Have you tried installing the RAM module over to the next slot?
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/770039-ryzen-5-1600-help/#findComment-9719088
9 hours ago, Banish72 said:
You keep quoting yourself, hence why people aren't getting notifications. Make sure you quote the person you're talking to to make sure that they know you replied.
Also, try going through the steps @-rascal- listed.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
https://linustechtips.com/topic/770039-ryzen-5-1600-help/#findComment-9719946
I put the ram on both sides didn't make a difference. But I'll do what is listed
https://linustechtips.com/topic/770039-ryzen-5-1600-help/#findComment-9720027
Hi i just got my ryzen 5 1600 and my msi B350M and 4gb of ddr4 ram, but the system wont boot i can't seem to find out why the only clue i got is the 4 leds on the mobo were only the cpu one lights up (means that something is wrong) but no matter what i do i can't find anyting online on how to fix it.
https://linustechtips.com/topic/770039-ryzen-5-1600-help/#findComment-9720073
So when you press the power button, the motherboard lights up?
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/770039-ryzen-5-1600-help/#findComment-9720077
You need a GPU. What PSU?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/770039-ryzen-5-1600-help/#findComment-9720109
The CPU led light turn on only
I'd check that you've inserted the CPU correctly and no pins are bent/missing.
VGA should be lighting up then, not CPU :P
https://linustechtips.com/topic/770039-ryzen-5-1600-help/#findComment-9720112
Overlooked that he said CPU light, whoops!
SPECS:
https://linustechtips.com/topic/770039-ryzen-5-1600-help/#findComment-9720118
1 hour ago, Banish72 said:
I have the seasonic 520 watt this is my build
https://pcpartpicker.com/list/r3GLBP
Make sure all your cables are connected properly.
SPECS:
https://linustechtips.com/topic/770039-ryzen-5-1600-help/#findComment-9720169
