Hey guys, according to task manager, my disk is running at 100% most of the time and the system and network processes are the ones hogging up the disk. Can anyone help me clear those up? I'm using Windows 10, and my specs are:
CPU- AMD A8 6500 with a stock cooler
PSU- EVGA 430W PSU
RAM- 8GB Generic DDR3 RAM from Samsung
MOBO- MSI 7778 (JasmineR) motherboard
Case- Fractal design core 1100 case- (one case fan)
GPU- Zotac GTX 1050 Mini
Storage- 2 TB Samsung HDD
https://linustechtips.com/topic/768321-help-disk-runs-at-90-100/
1 minute ago, Electronics Wizardy said:
What is running? Some updator?
It is also probably caching the disk on ram to make it faster.
Id let it sit for a hour and se if its still being used.
Yeah but the issue is that my PC (might be broken RAM or MOBO-- or even the Disk Usage) shuts off after about 10 minutes-20 minutes. It either shuts off or goes on standby so I don't have any way to make sure the issue isn't the windows files
https://linustechtips.com/topic/768321-help-disk-runs-at-90-100/#findComment-9699928
Specs?
Temps?
DOes it freeze or just turn off? bluescreen?
Id guess bad hardware, but you can check by using a different os, like linux on a usb stick.
https://linustechtips.com/topic/768321-help-disk-runs-at-90-100/#findComment-9699936
Just now, Electronics Wizardy said:
Specs?
Temps?
It simply shuts off like when you force a shut down. Just now I tried moving the 24 pin connector and it does the same thing every time I move it just slightly. Issue detected, but how do I fix it, and how do I know the MOBO isn't broken?
https://linustechtips.com/topic/768321-help-disk-runs-at-90-100/#findComment-9699954
What psu? you can work with connectors, but it can be a pain to deal with.
If the connector will power it off, then its not the board(other than maybe a bad connector.
https://linustechtips.com/topic/768321-help-disk-runs-at-90-100/#findComment-9699964
Okay, I'm an idiot. Apparently the hard drive was big and pushed the 24 pin cable so that it would be pulled away and caused random shut off. I'll still keep an eye out and see if it happens again, but now that I moved the cable and wiggled the connector while it was on the motherboard, it seems to be fine *facepalm*
https://linustechtips.com/topic/768321-help-disk-runs-at-90-100/#findComment-9699970
Back to the disk issue, I'll keep my PC on for about an hour and see if anything weird happens.
https://linustechtips.com/topic/768321-help-disk-runs-at-90-100/#findComment-9699973
Sounds like Windows 10
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/768321-help-disk-runs-at-90-100/#findComment-9700069
