First time liquid cooling, help!
Go to solution Solved by atomicus,
Don't waste your money on the H55. Small AIOs like that are just pointless and almost any decent air cooler will better them, plus it will be noisier. Unfortunately the S340 is slightly height restricted so several top end coolers just won't fit, but you should look closely at the Noctua NH-D14 or Phanteks PH-TC12DX. They will fit, and both will still perform better than most AIOs, particularly 120/140 size rads. 240/280 are better, but I wouldn't bother with the Seidon, it's not quiet and doesn't perform that well based on benchmarks I've seen. That said it is cheap, but you get what you pay for. You'll be better off with one of the above air coolers. The Noctua is slightly more expensive but will kick the Seidon's ass. AIOs aren't worth the money, even at the top end.
I was thinking about buying either Corsair Hydro Series H55 or Cooler Master Seidon 240V (case nzxt s340 elite red), I haven't checked if seidon would fit but it seems like it would. What do you guys recomand, also what precautions would I need to take if I use liquid cooling, never build a pc before. Also would it be enough for an i5 7600k overclocked?
https://linustechtips.com/topic/765532-first-time-liquid-cooling-help/
For maximum cooling potential a 240mm or 280mm rad would be ideal especially if you plan to overclock your system.
yeah should be enough
get the biggest one you can tho
with an aio there isnt anything to worry about so no 'precautions' to take (even with a custom loop if u do it right it will RARELY leak)
never get a 120 or 140mm aio
they all use slim rads which are bad enough but they cost too much and don't perform as well as a good air cooler
if u are going to get an aio always get the biggest one that will fit
System: Ryzen 7 5800X - Gigabyte X570 Aorus Master - Noctua D15S Chromax - 32GB 3600 RAM - EVGA Black 2080Ti
^ Agree.
If only doing the CPU, just through an air cooler on the it.
2023 BOINC Pentathlon Event
F@H & BOINC Installation on Linux Guide
My CPU Army: 5800X, E5-2670V3, 1950X, 5960X J Batch, 10750H *lappy
My GPU Army:3080Ti, 960 FTW @ 1551MHz, RTX 2070 Max-Q *lappy
My Console Brigade: Gamecube, Wii, Wii U, Switch, PS2 Fatty, Xbox One S, Xbox One X
My Tablet Squad: iPad Air 5th Gen, Samsung Tab S, Nexus 7 (1st gen)
3D Printer Unit: Prusa MK3S, Prusa Mini, EPAX E10
VR Headset: Quest 2
Hardware lost to Kevdog's Law of Folding
OG Titan, 5960X, ThermalTake BlackWidow 850 Watt PSU
