Hey folks, I just want some final thoughts on this build before biting the bullet since it will technically be my first. I don't have a PCPartPicker list, but I do have a screenshot of my Amazon cart. The CPU will be an R5-1600X (purchasing that from Newegg since the price is better there; doing Amazon on everything else because of Prime shipping). The S340 Elite is somewhat superfluous, but I'd rather have the tempered glass window instead of plastic.
Current Build:
CPU: Ryzen 7 5800X3D
GPU: RTX 3080 Ti FE
RAM: 32GB G.Skill Trident Z CL16 3200 MHz
Mobo: Asus Tuf X570 Plus Wifi
CPU Cooler: NZXT Kraken X53
PSU: EVGA G6 Supernova 850
Case: NZXT S340 Elite
Current Laptop:
Model: Asus ROG Zephyrus G14
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
CPU: Intel i7 8700K @4.9 GHz/1.315v
Mobo: Asus Prime Z370-A
https://linustechtips.com/topic/765309-final-thoughts-on-build-before-purchase/
Looks nice, but... GPU?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
I already have one. It's in my sig!
Current Build:
GPU: RTX 3080 Ti FE
Current Laptop:
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
take a look at the p400 tempered glass, integrated LED lighting for around the same or less. I'd get a better PSU, the B1 is mediocre.
Just now, deXxterlab97 said:
don't get a 700b1. it's bad
Can you suggest a PSU that can support all of that plus a 1070, but within $70, that passes the LTT community approval test
Current Build:
GPU: RTX 3080 Ti FE
Current Laptop:
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
https://www.amazon.com/dp/B003BIEOCI/?tag=pcpapi-20
Get the 1600 instead, and then OC it.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Just now, mutedcurmudgeon said:
Looks good, I'd say (like most others here) just spring a little bit for a G2 supernova, much better.
I can just barely afford the 650 Watt G2 Supernova. 650 should be enough for this, I assume?
Current Build:
GPU: RTX 3080 Ti FE
Current Laptop:
CPU: Ryzen 9 5900HS
GPU: RTX 3060
RAM: 16GB @3200 MHz
Old PC:
650 is plenty..
If you cant afford the G2, just buy the seasonic unit..?
1 minute ago, Aytex said:
650 is plenty..
Yeah 650 is good, I would think this system wouldn't make any more than about 400W (?)
Seasonic would work as well. I personnaly prefer the G2 with the fully modular capability and 80+ Gold.
