Fans! Need better fans.
Syphno
I'm currently streaming while gaming and I noticed the stock fans on my H100iv2 and my case fans ramp up and they get pretty loud my stream mic picks the noise up.
I have a Asus Z270a MB everything in my system is still stock I have not even adjusted the fan curves yet because I don't know how to tune then correctly.
My CPU load streaming and gaming only see's 40% and the average is about 33% on a 7700K, My GC is an ASUS strix 1070 playing PUBG. Somebody please help me with suggestions to help make things a little more quiet around here.
For an example of what it sounds like in my stream I have a past broadcast up on Twitch.tv/thypnotics
thank you
Buy bequiet! fans ;)
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
6 minutes ago, Syphno said:
Do you usually have the case opened or closed? Is it placed on the desk near the mic or not?
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
Case closed, On Desk 3 ft away from mic
Try placing it away from the mic, maybe on the ground. Also what mic do you use? It has that protective(or for whatever it is used) foam?
TO BE UPGRADED:
Get Noctuas man, their color scheme will make any build pop.
Quote and/or tag people using @ otherwise they don't get notified of your response!
The HUMBLE Computer:
AMD Ryzen 7 3700X • Noctua NH-U12A • ASUS STRIX X570-F • Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz CL16 • GIGABYTE Nvidia GTX1080 G1 • FRACTAL DESIGN Define C w/ blue Meshify C front • Corsair RM750x (2018) • OS: Kingston KC2000 1TB GAMES: Intel 660p 1TB DATA: Seagate Desktop 2TB • Acer Predator X34P 34" 3440x1440p 120 Hz IPS curved Ultrawide • Corsair STRAFE RGB Cherry MX Brown • Logitech G502 HERO / Logitech MX Master 3
Notebook:  HP Spectre x360 13" late 2018
Core i7 8550U • 16GB DDR3 RAM • 512GB NVMe SSD • 13" 1920x1080p 120 Hz IPS touchscreen • dual Thunderbolt 3
Hello there!
Personally, I would recommend a pair of Auoker 33 LED Grid 120mm fans. Without doubt, there included LES illumination is amongst the most spectacular. Follows by such is there reasonabley awesome specifications with virtually silent operation (I have two White ones as intakes, I literally cannot hear such even when both are on Molex). Excluding there low MTBF these are incredible fans, especially for there price.
Noctua NF-F12s do have impeccable construction qualities as well, with very low operating noise output, although they are rather pricey if I may admit.
I hope this helped!
-EnergyEclipse
I once did the unthinkable, back many headphones ago...
I split an audio split, again
48 minutes ago, EnergyEclipse said:
Hello there!
I hope this helped!
-EnergyEclipse
Just ordered 2, they better be quite or my last option is to give my PC a pepsi
Two Auoker fans? Which colour? :o Well, I do sincerely hope they serve you as well as they do me! :D
-EnergyEclipse
These fans come in many different brands, and I've got the "GameMax" version of these fans. The LEDs are quite bright, they're not particularly good fans but they're cheap and quiet. I did notice that they start to squeak when they're running for 8 hrs+ continuously. Tbh I wouldn't recommend these to be used on a radiator, but they're nice case fans thanks to their quietness and bright LEDs. I'd recommend something like Noctua F-12s, Scythe Grand-flex (2000 rpm or PWM versions), or Corsair SP-120s. Arctic F12s are a good budget option too.
REMILIA Mk.IIIE CPU: Ryzen 9 3900X, Cooler: Arctic Freezer II 240 (Noctua NT-H2), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives 1-4 TB, PSU: Corsair RM750 MY2019, Case: Cooler Master Mastercase 5 MC500 (with add-ons, Noctua NF-A14 and Arctic P14 fans), PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), Hp Z27n (IPS, 60hz, 1440p, 8Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, ifi Zen DAC v2 + ifi Zen CAN, Littledot Mk.II (w/ Soviet Power tubes and British Mulard M8100s/Soviet Voshkod 6JP-EV/ American General Electric JAN 5654W dependent on mood), Sendy Aiva (Primary), Beyer Dynamic DT990 250ohm Black Special Edition, Audeze EL-8 Open Back, Sennheiser HD598SE (modified to be a headset, snapped headband held together with gorilla tape), Mouse: SteelSeries Rival 600, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
KOAKUMA Mk.IB (24/7 Folding Slave PC made of spare parts): CPU: Core i7 4770, Cooler: Some small antex cooler with 80mm fan, RAM: 2x 4Gb Sticks of 2400Mhz DDR3, Mobo: Asus H81i-Plus, GPU: R9 390 Nitro+ (barely fits in case), Storage: 256gb Korean no-name SATA SSD, PSU: Corsair CX550 (Gray label), Case: Antec ISK600 ITX case. [Given away to friend]
I do believe the GameMax one's aren't as quiet as Auoker, although I think that may just be credit to a slightly higher RPM, with greater airflow delivery at a maximum of 87 CFM. On WaterCooling UK they have no static air pressure rating for those though? Eight hours a day as well... xDD That is a lot of gaming time
Just now, EnergyEclipse said:
I do believe the GameMax one's aren't as quiet as Auoker, although I think that may just be credit to a slightly higher RPM. Eight hours a day though? xDD That is a lot of gaming time
I spend a lot of my time at my desktop, since my occupation demands it ;)
