Hey Guys
I just picked up a new 780 Ti from zotac, I am having some oc problems with it, i have am only getting a boost clock of 1220 on it right now on default voltages, the temp is around 85 degrees. What am i doing wrong, all i did was i put the power target at 106 percent and chose +225 on gpu clock offset and made the temps priorities. Do i just have a bum card :(. Additionally ASCi rating is only 69.3 percent on this thing, should I try to get another one?
https://linustechtips.com/topic/76457-oc-problems-with-my-780-ti/
:o
I would call that a pretty good oc to be honest. 1220 Mhz.
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
Hey Guys
Not all cars are very overclockable instead of saying its bad say its normal
Why do you need to overclock it? It's overkill GPU itself, even without OC.
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
I'd say thats a pretty good overclock. Not to mention its a zotac, isnt that about the cheapest card you can buy. I think your expectations might have been alittle high. I'd be happy though, its a good card, and good overclock. It could be worse, you caps could have exploded, or it could have been doa, or artifacting like crazy. Enjoy your card :)
Main Rig: http://linustechtips.com/main/topic/58641-the-i7-950s-gots-to-go-updated-104/ | CPU: Intel i7-4930K | GPU: 2x EVGA Geforce GTX Titan SC SLI| MB: EVGA X79 Dark | RAM: 16GB HyperX Beast 2400mhz | SSD: Samsung 840 Pro 256gb | HDD: 2x Western Digital Raptors 74gb | EX-H34B Hot Swap Rack | Case: Lian Li PC-D600 | Cooling: H100i | Power Supply: Corsair HX1050 |
Pfsense Build (Repurposed for plex) https://linustechtips.com/main/topic/715459-pfsense-build/
Yeah I am reading its very hard to get one that is 1300 on stock, my friend just bought 2 for his sli. they are both doing 1300 on air with no tweaking to voltages. I think i can haggle one off him as he only plays with stock hardware. I am very picky about my hardware lol, my current cpu i went through 4 of them until i found one that can do 4.1 on low voltages
Depends what res he's play at. It's not overkill at 1440P if you're playing games like Crysis 3, Tomb Raider, BF4 etc...
