6 minutes ago, Big_Cazza said:
i feel like it should run cooler than this tho, considering it was at 80c with a hyper 212x
under prime95 at 1.33v? i doubt that
btw if you don't quote me I wont see it.
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9647912
75C on Prime95 is a really good temperature.  Don't delid your CPU for that.  Maybe if it was reaching 90C+, but not 75C.  Hell, 80C was great.  Prime95 doesn't represent realistic temperatures.  It's just to see if your PC will crash.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9647952
its not really that good considering that my pump is at 100 percent and the fans are also close to it, i would like to bring down temps because i know it will do 4.7ghz at 1.42 volts and ive seen lots of haswell chips do that voltage without getting too hot
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648018
A Haswell CPU might be able to do 1.42V if you were using liquid nitrogen or something, and even then it would cause serious damage to the CPU.  Going above 1.3V on Haswell is a bad idea.
I don't think you understand how stress tests work.  The fans are supposed to be 100% during those.
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648022
in games it hovers around mid 50s is that good?
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648031
Yes.  That's 40C less than when the chip starts thermal throttling to lower temps.  Mine is around 60-65C when playing games.
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648044
so realistically as long as it runs under 100 in stress tests its fine for general use, so i could probably put it back to the 4.6ghz oc that runs 1.37 volts
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648048
It should run under 90C at stress tests for stability.  Usually people push to see what they can get at ~85C.
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648050
ok, should i try and push for just core clock or a bit of cache as well
I don't recommend increasing the voltage.  You're already above recommended levels.
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648058
ok fair enough, i think my chip lost the sillicon lottery, im probably gonna just get a 4690k when i can afford but i live in australia so everything is overpriced, like an i5 brand new goes for like 370 bucks
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648061
Haswell can take a lot more than you think as long as temps are kept under control. And by under control I mean well under 85C in a heavy stress test over a good length of time.
My 4670k for example ran 4.7 at 1.45v for months on end with no degradation, but my water loop kept it well below 70C even running prime 95.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648068
considering that its like a 100 dollar chip i want to just see what it can do, i might delid and push it hell far after i have a 4690k ready to swap in
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648080
How do you know there was no degradation?
Also, it really the luck of the draw.  Not everyone is as lucky as you.  Even the idle temps start to spike at 1.3V on my 4790K.
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648087
what sort of frequency did you get at 1.3? i heard that haswell refresh tends to be slightly better with overclocking than the original haswell cpus
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648101
Guess so. My 4790k can hit 5.0 at 1.35v but temps outpace my current cooling setup.
Soon. Soon I will have that fixed.
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648117
Damn, you really won the silicon lottery.  All I can get is 4.6GHz at 1.3V without crashing.
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648135
if i put 1.42 volts in my cpu and temps stay under 85 how long do you think the chip will last?
I don't know.  I can't imagine your temps will stay under 85C at that voltage though, unless you have a badass custom cooling loop.  You should bump up voltage by 0.01 at a time.
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648161
i dont have a custom loop but i have a deepcool genome rog edition that has a built in 360mm aio, surely its worth a try, if i can at least squeeze 4.7ghz out of it
https://linustechtips.com/topic/763616-overheating-g3258/#findComment-9648167
