Help me choose a motherboard...
Solved by FlightRisk,
Oops about the 4 months, oh well.
I may have missed some features as it is rather late where I am and am very tired.
Incase you did not know when it comes to selecting a Motherboard on PCpartpicker you can narrow down the searches quite a lot. Check the below link out if the above Motherboard doesn't meet your requirements. There is about 25 Motherboards (maximum) to look at in price order so it should make your selection much much easier. The main holdout on requested features I could see from quickly looking at the cheapest Motherboards there was a dual BIOS/recovery feature.
Hope this helps.
