USB WiFi Sticks
Just now, techstorm970 said:None, really. Just something with a good price to performance ratio.
TP-LINK TL-WN722N is a great little wifi dongle, i would recommend that on the cheap side. i actually own it and it comes with an usb extension cable so you can put it high for better reception or something like that. but it depends on your enviroment really what will be good enough for you. just getting one and returning it if it doesn't live up to expectations is the best way to go about it if you ask me. the TP-Link AC600 is its upgraded brother that has 5ghz capability's but i don't actually own it so i can't really recommend it.
the TL-WN722N has a max troughput of 150mbit, in the real world that would be like 40mbit per second or something like that depending on your setup.
