LED Case Fans
Go to solution Solved by I'm Batman,
i think the Cooler Master JetFlo are THE BEST  looking LED fans atm check them out ;)
No RGB LED fans other than ones with rainbow colors :(
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/76089-led-case-fans/#findComment-1043297
found these, but when you make a computer it usually is better to keep a simpler theme. Something that is two tone is usually better.
http://www.amazon.com/CoolMax-Chameleon-7-color-140mm-case/dp/B004SU8ANM
This is my opinion, it doesn't mean I'm right and is liable to change at any time. I may offend of which I apologize in advance.
(Our lord and savior: GabeN)
https://linustechtips.com/topic/76089-led-case-fans/#findComment-1043307
After looking around, I think I'm gonna just go with blue. I wanted Corsair's AF120s but they aren't in stock. Thinking about these http://www.nzxt.com/product/detail/93-fz-120mm-led-case-fan.html.
I also saw these http://www.amazon.com/NZXT-CB-LED20-BU-2-Metres-Sensitivity-Sleeved/dp/B0046Y5Z5G/ref=sr_1_1?ie=UTF8&qid=1384437686&sr=8-1&keywords=nzxt+sleeved+led+kit
Would they be overkill together or just go either-or?
https://linustechtips.com/topic/76089-led-case-fans/#findComment-1043492
No BitFenix Spectre posts yet? I'm impressed.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/76089-led-case-fans/#findComment-1043671
He is the hero this forum deserves but not the one it needs right now.So we'll hunt him because he can take it because he is not our hero he is a silent guardian
a watchful protector A Dark Knight
https://linustechtips.com/topic/76089-led-case-fans/#findComment-1044376
