Just now, deXxterlab97 said:
Again I don't want to spend that much. I would instead sell my RX 480 and get a different GPU instead if I have to ghetto do it
Try a new case then, one with good airflow could help massively
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/757073-cooling-solution/page/2/#findComment-9572645
2 hours ago, Janner558 said:
I think jayztwocents made a video on this same issue
Please could you short up your huge unnecessary quoting? [:
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/757073-cooling-solution/page/2/#findComment-9572682
3 hours ago, deXxterlab97 said:
It's a  PowerColor RED DRAGON RX 480 4GB (AXRX 480 4GBD5-3DHDV2).
Well theres your problem. It's not blue!
https://linustechtips.com/topic/757073-cooling-solution/page/2/#findComment-9572726
2 minutes ago, deXxterlab97 said:
true. i could replace the stock ones. i mean the tubing.
You should be fine but check this out:
http://www.kijiji.ca/v-computer-components/markham-york-region/nzxt-phantom-eatx-full-tower-pc-gaming-case/1243721449?enableSearchNavigationFlag=true
This case is awesome and for an extra $20 and some DIY you'll have a great case and more than enough room for an AIO, even a 240mm one later
https://linustechtips.com/topic/757073-cooling-solution/page/2/#findComment-9572767
thanks time to find out a way to ghetto mount an aio to my card.
https://linustechtips.com/topic/757073-cooling-solution/page/2/#findComment-9572779
It uses the same mounting hardware as you're CPU.  Use a small copper shim ($1.50 or so) and fasten it on
https://linustechtips.com/topic/757073-cooling-solution/page/2/#findComment-9572783
Zip ties should do the job hopefully. Though not sure about buying a used aio
One of them seemed to be new in box, though the H60s should be fine.  Corsair has a 5 year full  warranty
https://linustechtips.com/topic/757073-cooling-solution/page/2/#findComment-9572796
1 hour ago, deXxterlab97 said:
Would it though? Or would a new cooler do better? Considering I had an old oem gtx 760 in there and didn't get that high temps in the same case
It definitely would. You have insufficient airflow. When I was still using my define nano s, I got a 10c temp drop just by swapping out the stock exhaust fan. Airflow is your problem here.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/757073-cooling-solution/page/2/#findComment-9573000
3 minutes ago, Droidbot said:
they're quite good at low rpm, commonly used in dell and hp desktops so they're quite common
Where can one find those? I might want a few
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/757073-cooling-solution/page/2/#findComment-9573170
