So I might start to think about making this beast cooler and quieter. Sits around 83 on load which is not pleasant at all. And fan speed has to be around 70-80% or so too
It's a  PowerColor RED DRAGON RX 480 4GB (AXRX 480 4GBD5-3DHDV2).
RMA isn't gonna work sadly, I will try but right now I kinda given up a bit
Well the first thing to do is reapply thermal paste? But would it help? I know it would but will the result be significant? I don't want to waste money on that (even though Thermal paste are fairly cheap)
Slap an aftermarket cooler/fan seems like a good choice (guide me please). Low cost would be nice too so throw some suggestions.
Obviously I have no money for a custom/liquid loop.
Also I noticed Tomb Raider got a ridiculously low frame rate after overclocking. First time I ran the benchmark it got this result which was really nice (taken from my YT video)
And when I reran again I got a quite low FPS. So could it be thermal throttling already?
Valley scores are good. The whole test ran fine on Extreme HD. I ran several times too all stable
But temps were below 80 degrees (up to 79)
https://linustechtips.com/topic/757073-cooling-solution/
Here is a proper solution but if you have a big enough case you can actually use some full size CPU coolers on GPUs
https://www.amazon.com/gp/product/B006DAD8HS/ref=ox_sc_act_title_1?smid=A3DWYIK6Y9EEQB&psc=1
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/757073-cooling-solution/#findComment-9571762
get an Accellero Twin Turbo III. i have one on my 970 and it never goes above 50C anymore :D i do run 100% fan speed though but its insainly quiet compared to the Gigabyte G1 cooler that was on it even maxed out
Builds:
https://linustechtips.com/topic/757073-cooling-solution/#findComment-9571799
Here it is for a 480 as well :D
http://www.overclock.net/t/1604989/rx-480-with-arctic-accelero-twin-turbo-iii
https://linustechtips.com/topic/757073-cooling-solution/#findComment-9571811
My god is that thing ugly.. But if it works and won't sound like a small jet engine..
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/757073-cooling-solution/#findComment-9571827
  Reveal hidden contents
I think jayztwocents made a video on this same issue
Desktop: Cooler Master MasterCase 5 | i7 6700k @4.7GHz 1.3v | Custom EKWB soft-tubing loop (CPU + GPU) (2x 240mm Alphacool rads)| Zotac GTX 1080 Founder Edition | Asus Maximus VIII Hero Motherboard | Samsung 850 EVO 512GB SSD | 4TB Seagate HDD | 2TB Seagate HDD | EVGA SuperNova G2 750 | Acer Predator XB271HK | https://uk.pcpartpicker.com/list/xzjRHN
https://linustechtips.com/topic/757073-cooling-solution/#findComment-9571936
53 minutes ago, Damascus said:
That shit looks expensive, already 46 usd. I want something like an aftermarket cpu  cooler I can slap it somehow, and mine is a single cooler anyway
Mine can maybe hold a LP one
Here is the picture inside
1 hour ago, TheGhzGuy said:
Thermal past can help. Is there a fan in front of the GPU in your case?
Single fan. There are some holes look at pic above. How much would that help? Maybe reapply thermal pads too?
Stop complaining about cable management
1 hour ago, Zackbare said:
I've seen vids where reapplying thermal paste decreases 3 degrees and sometimes even 5 degrees, but that is not the best solution for you.
A 78 ish looks still better than going around 80 degrees
Can you link me the video?
you mean the twin turbo thingy?
https://linustechtips.com/topic/757073-cooling-solution/#findComment-9572089
My bad it a gigabyte card
https://linustechtips.com/topic/757073-cooling-solution/#findComment-9572120
  Hide contents
Reapplying thermal paste? 3-5c probably. Since your GPU is pretty new, I think you should keep those thermal pads. I should be able to get results from my fan test within about a week. If it works, I'll send you a fan and a shroud for you
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/757073-cooling-solution/#findComment-9572123
there are cheaper and smaller ones aswell, all Accellero cooler are good
Builds:
https://linustechtips.com/topic/757073-cooling-solution/#findComment-9572127
Hmm is it universal? Ie work on every card
most of them work on almost everything from the 8800GT to the TITAN XP basically. check compatability on their site first though. i had some problems with installing it on my 970 but it was super worth going through the troubble. the 970 G1 PCB has the VRM by the display out end of the card instead of the normal place of litteraly the other end of the PCB lol
Builds:
https://linustechtips.com/topic/757073-cooling-solution/#findComment-9572212
Paste, undervolt. Can you post pics of your case?
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/757073-cooling-solution/#findComment-9572233
12 minutes ago, deXxterlab97 said:
Look above at spoiler tags.
Okay. A new case would make a world of difference.
https://linustechtips.com/topic/757073-cooling-solution/#findComment-9572310
1 minute ago, deXxterlab97 said:
Would it though? Or would a new cooler do better? Considering I had an old oem gtx 760 in there and didn't get that high temps in the same case
you could get a new case for $30-50 and a Hyper 212 or similar for $25-50
https://linustechtips.com/topic/757073-cooling-solution/#findComment-9572633
