In small cases how important is rear exhaust vid card?
atavax
I think my next case is going to be mini itx, and i'm currently thinking about upgrading my videocard and I want one that will run well in a mini itx case. Beside avoiding excessively large ones, i have heard you want rear exhaust. Is rear exhaust really important? And are there better options for a rear exhaust card than the founders edition?
Well you can skip it and just get a case that have slots for good case exhaust fans.
If your case has ventilation where the fans exhaust, you can get away with a non ref card. If there is no path for air flow, get reference style if it's cramped.
depends if the sidepanel has ventilation or not and how big the case is
Builds:
