Hello I have a little question ?
So I want to clean my ''old'' thermal paste on my I7 6700K, BUT I dont have alchool 99%....
Is there a new method ?
Thank you :)
AMD - Ryzen 5 2600 3.4GHz 6-Core / Evga 1070ti ftw 2 8 gb/ MSI B450 tomawack / Stock cooler/ G.SKILL 16gb 3000mhz RGB / 860 evo 500 GB /  XL2411 144HZ  / Western digital blue 1 TB 7200 RPM/ Corsair 760T (white) |Window 10 pro
https://linustechtips.com/topic/754659-need-help-please/
Aceton, but don't get it on anything other than CPU. It will damage the motherboard. CPU IHS will be fine tho. You can get away with any alcohol liquid as long as it's above 75% (don't quote me on that one). You don't want water tho. Use it as complete last resort but turn everything off and hold the power button so everything really is dead. And even then don't get it on the MB.
https://linustechtips.com/topic/754659-need-help-please/#findComment-9544285
It is true that I can use a little water for clean ?
https://linustechtips.com/topic/754659-need-help-please/#findComment-9544484
