Why 1-2 fps difference between 1080 ti ref and strix 1080 ti ?
zzz123
1 minute ago, zzz123 said:
1-2%. This doesn't mean 1-2FPS
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
It's factory overclocked. Also, that's not FPS, it's relative performance in %, the difference is more than 2FPS. Look at the benchmarks for the individual games in the review to see the FPS differences.
Because the GPU is exactly the same. Board partner cards can be quieter, run cooler, and subjectively look better.
But the same GPU means the performance is the same.
If anyone asks you never saw me.
But they saying for example GTX 1080 ti ref - 90 fps
GTX 1080 TI STRIX - 92 fps
What? Where?
Where are they saying this?
Could be clock speed is different or margin of error.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
Custom cards are often factory overclocked, which translates to more heat, more performance. And this is where the beefier cooler comes to play.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
1 minute ago, Oshino Shinobu said:
Have a look at some of the actual FPS numbers
You mean the ones that don't account for clock speed?
The overclocking potential is up to the lottery, not who made the card.
But few people want a hair dryer in their case, so we buy board partners.
Any ideas about thermal throttling? What are max temps and how much fps will i lost when thermal hits?
they are based on the same GPU, so thermal throttling will affect both the same, and they should kick in roughly at the same temp
But i ask about referent 1080 ti. What are max temps load and how much i lost fps then .
Just now, zzz123 said:
But how is on stock fan settings?
It's alright, but a aftermarket card is definitely much quieter and cooler in most cases. I would honestly stay away from reference cards.
Founders? Sucks.
The Founders card is not meant for the average gamer. They're meant to be used in racks, places with poor airflow, and SLI.
FE for small cases (slim or mini-towers) and SLI.
AIB for everything else.
Thermal throttling should kick in about 90C+. How much FPS you lose really depends on the extent of the thermal throttling, as the more the card has to reduce clock speeds and power draw, the more FPS you'll lose. You'll lose less FPS if the GPU is only just hitting the thermal throttling point, but if it's really hot in the case and the card's not getting enough air, it will throttle more to keep temps down, losing more FPS. It's hard to tell you exactly how much FPS you'll lose as it changes for difference conditions.
From basically the 700 series and up (pretty much anything with GPU Boost 2.0 or greater), the reference Nvidia cards seem to like running at 82-84C, pretty much regardless of your settings. If you look at Techpowerup's temperature results, both the 1080Ti FE and the Titan XP run at 84C under load.
Honestly, if you're using a case that has decent airflow, try to go for a card with an aftermarket cooler, it will work better and chances of thermal throttling will go down significantly. In their testing, the Strix card only got up to 69C.
My case is Centurion Cooler Master 590. Its big case from 2008 year.
Any ideas? Will it throttle much more ?
