How to control fans
Solved by LogicalDrm,
Asus boards have excellent fan control with Fan Xpert. You can connect all fans to mobo. From BIOS select headers to use DC control instead of PWM. Then you can adjust curves within BIOS or with Windows software.
E: I don't know if Asus software can use other temp sensors than just CPU. Speedfan is the only other option and that can use any mobo sensor or GPU temp.
Featured Topics
RevGAM ·
Posted in Custom Loop and Exotic Cooling0 -
JakubR88 ·
Posted in Power Supplies2 -
1
2
4
4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
